Go Back   Preludepower.com > Prelude Forums > 3rd Gen
Reload this Page How to paint your calipers and change your brake pads!
Reply
Ads By Google
Thread Tools Display Modes
Old 07-11-2006, 12:51 AM   #1
m1k30rz
JDM fo lyf y0
m1k30rz's Avatar
m1k30rz is on a distinguished road
Send a message via MSN to m1k30rz
Hey Guys,
Okay well I painted my calipers some time ago and was going to write up a howto and thought I lost my pictures but I found them today! So I will post up my howto :]
Ingredients
You need basic tools, break cleaner and some caliper paint of your choice (i chose this caliper spray paint as it has primer and everything built in so its just one step! very easy) I chose to paint mine silver as it matches the wheels and will blend in quite nice and not look all ricey and out of place! Gold would also look quite nice IMO. you will also need a wire brush thingy or some sandpaper.
Step 1:
Raise your car on jackstands (BE SAFE PEOPLE USE JACKSTANDS PLEASE) and take both front wheels off (we are doing the front for now).
You will be greeted with this pretty sight :]
Now heres a rule for this guide, keep one side fully intact do not take any of it apart until you've COMPLETLEY finished the first side, why? So if you forget what way round that pad/shim/caliper/bolt goes you can look at the other side! Saves messing up now
Step 2:
Remove the calipers bottom bolt on the rear of the caliper
Now swing the caliper up, depending on what kind of break disc quiet has been used etc it may be VERY TIGHT to lift up, Pull hard, it will come up Just not TOO hard dont want to snap any break lines or anything!
Now you've got it up pull it towards you a little bit and let it back down, it will niceley rest on the existing brake pads as seen in step 3
Step 3:
Now we want to clean that caliper! Get out your sandpaper or wire brush and break cleaner, spray a good ammount of break cleaner all over it and then get to scrubbing! You want to remove ALL dirt/rust that is on the caliper, now let it dry and spray it hard out again to remove all the dirt/rust you broke free.
Repeat if necessary.
Should come up nice and clean like this
Step 4:
Lets get to painting! First we must block off anything we DONT want to paint, that would be our brake rotor! I dont think it would be too happy with paint on it!
As you can see I used a plastic bag and put it up under the caliper covering the caliper piston as well.
Spray a good nice even coat and let it dry (says to let dry for 15 mins)
Now give her a few more coats (waiting in between 15 mins each time) until it has the desired finish, more spray = more shiney.
Step 5:
I let it dry for a good 4hrs before I went on so depending on your climate etc wait till its dry, we dont want to scratch up our nice painted calipers do we?!
Using a brake disc caliper piston pusher tool (available from most automotive shops) I pushed the caliper piston in, I put the tool into the caliper and put an old brake pad up to the piston and turned the handle and it pushed it in perfectly and evenly.
Make sure you do this with the master cylinder resivor OPEN and a towel around it! Some brake fluid may come out!! you do NOT want this on any paintwork, nasty stuff!
Now that the caliper was pushed in I got my new brake pads, these are Lucas non asbestos pads, they have EXCELLENT braking performance and dont create much dust, and they have many more great features I reccomend them! They also have rubber shims on them so you do not require the OEM metal shims.
I used some CRC Disc Brake Quiet on the back of the pads, shop manual says you must use some form of disc brake quietner/lubricant on the back of the pads and shims (if you have metal shims)
When it has dried but still tacky (about 10 mins to get to this stage) place the pads into the pad retainers then close the caliper over top of the pads and put the bottom bolt back in and tighten it up good! (not too tight though)
If you need any more help with changing the brake pads visit the shop manual http://media.honda.co.uk/car/owner/m...sf100/13-7.pdf
Done!!
Now you can do the other side :] once both sides are done put the wheels back on and put the car back on the ground make sure all lugnuts are tightend!!
Get into your car and start her up, pump the brakes SEVERAL times as hard as you can to seat the pads properly.
Take her for a nice drive and enjoy!!
__________________
JDM 1990 Honda Prelude SiStates - B21A - 5 Speed!!
m1k30rz is offline   Reply With Quote
Old 07-11-2006, 03:25 AM   #2
diamondsleeper
Donating Member
diamondsleeper's Avatar
diamondsleeper will become famous soon enough
Thanks for the pics. In the process of painting mine. Didn't realize the pads were visible till I saw your pics. Will be painting them now too.
__________________
Rebuild Thread:
diamondsleeper is offline   Reply With Quote
Old 07-11-2006, 06:04 AM   #3
cidgrad130
Donating Mem..car fanatic
cidgrad130's Avatar
cidgrad130 is on a distinguished road
I hope you didn't mean you were planning on painting the back sides of the pads. He didn't paint the pads for looks...he "painted" them with disk quiet produce (there are several manufacturers of that type of product), not paint. (maybe I misunderstood your post).
Cheers!
__________________
Cidgrad130
cidgrad130 is offline   Reply With Quote
Old 07-11-2006, 06:26 AM   #4
Tecknixia
Preludepower Member
Tecknixia is on a distinguished road
Better then painting the front sides... lol
__________________
1991 Prelude Si (
1991 Prelude 2.0 Si with JDM engine (backup car)
Tecknixia is offline   Reply With Quote
Old 07-11-2006, 06:28 AM   #5
LudaPower
LudaPower's Avatar
LudaPower has a spectacular aura aboutLudaPower has a spectacular aura aboutLudaPower has a spectacular aura about
Send a message via MSN to LudaPower
Also don't expect the paint to last forever. Brake pad dust is a bitch.
Also you can simply use a C-clamp to push the piston down.
__________________
LudaPower is offline   Reply With Quote
Old 07-11-2006, 01:30 PM   #6
Hprelude5R
Hprelude5R's Avatar
Hprelude5R will become famous soon enoughHprelude5R will become famous soon enough
Send a message via AIM to Hprelude5R
Simple task, yet highly appreciated. Good write-up. Should be stickied for all forums to utilize.
Rep point for you. YAY!
__________________
PP.COM NEEDS YOU! We've lost sponsors as of the new year. Donate to this valueable resource today!
showroom
GIT YO HANDS OFF MY S2000 BY-ITCH.
I like to consider myself a pretty decent jerk, but I still have aways to go I think.
yeah, you pretty much do
Hprelude5R is offline   Reply With Quote
Old 07-11-2006, 05:55 PM   #7
snickells
Newbie
snickells's Avatar
snickells is on a distinguished road
I have two cars, my 3rd gen and my s14 and BOTH need this done. Thanks for the inspiration!
__________________
snickells is offline   Reply With Quote
Old 07-11-2006, 07:05 PM   #8
m1k30rz
JDM fo lyf y0
m1k30rz's Avatar
Thanks alot guys :] Cheers for the rep HP5R!!
__________________
Old 07-11-2006, 07:17 PM   #9
reptar_head
True Luder
reptar_head's Avatar
reptar_head is on a distinguished road
The only thing you forgot is that to do a proper brake job, you should turn the rotors. I know it's a pain to take them off and take them somewhere, but if you don't you may end up with a shudder, noise, or any other number of brake problems. Even better than taking them off is turning them with an on-car lathe. When you do that, it cuts them as they sit on your car, so any imperfections or difference you have when they're mounted are compensated for.
__________________
My Mustang cardomain--->
My girlfriends Prelude cardomain--->
Trust me, I'm a Tech at a Honda/Nissan dealership
reptar_head is offline   Reply With Quote
Old 07-11-2006, 07:35 PM   #10
Prelude of Red
OBSOLETE
Prelude of Red's Avatar
Prelude of Red is on a distinguished road
Send a message via MSN to Prelude of Red
I replaced my front rotors and pads a few months ago, but now I want to paint them. Thank you for the write-up and pics.
__________________
Prelude of Red is offline   Reply With Quote
Old 07-12-2006, 10:03 AM   #11
CADster
Kickass truck missed
CADster's Avatar
CADster will become famous soon enoughCADster will become famous soon enough
Prelude of the Month
waste of time. it wont stay. pads get too hot.
just paint the caliper.
ive already got a few spots on my caliper where my brake temp has got so hot its bubbled my rotor paint.
__________________
"Straight-line acceleration is probably the first aspect of automotive performance
that any intelligent driver gets bored with." - Peter Holden Gregg
sigh....i need about 3" to get this 3" down pipe to fit.
CADster is offline   Reply With Quote
Old 07-29-2006, 04:48 AM   #12
m1k30rz
JDM fo lyf y0
m1k30rz's Avatar
Wow CADster havent managed to do that to mine yet LOL.
Also to keep them looking great use some degreaser on them when you wash your car, keeps the paint finish looking good :] Mine are still looking GREAT by cleaning them with degreaser (wheel still on, as long as you can actualy get to the caliper) every time I wash!
__________________
Old 07-29-2006, 05:07 AM   #13
DAAMANNN
Preludepower Member
DAAMANNN's Avatar
DAAMANNN is on a distinguished road
Send a message via MSN to DAAMANNN
should have painted the bracket aswell. I did, it looks sikkkk
DAAMANNN is offline   Reply With Quote
Old 07-29-2006, 05:56 AM   #14
dano
Preludepower Member
dano has disabled reputation
You also need to clean the slider pins, the holes they go into and re-grease with caliper grease.
I find a .38 or 9mm caliber brass bore cleaning brush to be perfect to clean old grease out of the pin holes. That is if gun cleaning supplies are not illegal in NZ.
I like your red knobed piston retractor. I'm a big fan of these things. If you are unable to push the piston back into the bore by turning the knob, the caliper need a rebuilding. A "C" clamp offers too much leverage.
Good job. You have a lovely Prelude.
__________________
dano is offline   Reply With Quote
Reply
Bookmarks
  • Submit Thread to Digg Digg
  • Ads By Google
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b21a1 car motivational posters convertible prelude dashboard paint edge2lyfe view profile floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22a4 specs h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen how to text your girlfriend hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews pcv valve symptoms power prelude prelude prelude convertible prelude forum prelude forums prelude power preludepower preludepower.com projector retrofit racing hart cp-035 rattle can paint job song suggester sweet things to say to your girlfriend in a text sweet things to say to your girlfriend over text sweet things to text your girlfriend things to text about things to text your girlfriend what to text your girlfriend www.preludepower.com
    Thread Tools
    Display Modes
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Forum Jump
    KickItBack = Cash Back
    Google
    vB.Sponsors
    PreludePower Forums
