car bogs out at high rpm - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 05-27-2006, 06:45 PM   #1
delude
Getting Comfortable
delude's Avatar
delude is on a distinguished road
Send a message via AIM to delude
i finally got my motor in good shape and everything.. but now when i get to about WOT during accelleration the car wants to bog down till it reachs lower rpms.. and will happen again if you hit the gas.. just wondering if anyone had any ideas on this.. there are no trouble codes or anything either
__________________
a good nights sleep just means you had a really boring night..
delude is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-27-2006, 07:32 PM   #2
FrozenStreaks
Ludacious
FrozenStreaks's Avatar
FrozenStreaks has disabled reputation
Send a message via AIM to FrozenStreaks
You should search. My car bogged down also about a month ago. You may need to clean your EGR ports, that could cause it. Make sure you check your spark plugs, make sure they are all the way in. Make sure your distributor cap has no carbon traces. Does it idle rough?
__________________
That's awesome. The girl always gets pissed off in the lude. She looks for the cupholders, and then sighs when she remembers that she's the cupholder.
LOL
FrozenStreaks is offline   Reply With Quote Quick reply to this message
Old 05-27-2006, 07:46 PM   #3
Run_Away
Lude Boss
Run_Away's Avatar
Run_Away will become famous soon enough
Prelude of the Month
Timing belt done recently?
__________________
-Ben
Run_Away is offline   Reply With Quote Quick reply to this message
Old 05-27-2006, 08:16 PM   #4
HondaPowa
True Luder
HondaPowa's Avatar
HondaPowa is on a distinguished road
fuel pump/filter?
__________________
My old 3rd gen.....
'98 Prelude 5spd winter car (a really fun winter car)
'91 CRX si with mini me VTEC swap (in hibernation)
HondaPowa is offline   Reply With Quote Quick reply to this message
Old 05-28-2006, 02:15 PM   #5
motoxxxman
motoxxxman is an unknown quantity at this point
Send a message via AIM to motoxxxman Send a message via Yahoo to motoxxxman
when's the last time you did a full tune up? ie: cap, rotor, plugs, wires, oil change, pcv valve, air filter, fuel filter....
usually bogging at higher rpm is due to lack of fuel. caused by several possible culprits: TPS, fuel filter, fuel pump, fuel pressure regulator sticking part way open, MAP sensor, clogged injector[s] or faulty injector[s]...
theres a slight chance it could be ignition related: coil, cap rotor plugs and wires, resistor box...
anything else other then the things listed should throw a code. so if you have no trouble codes at all, then i would say its one of the above listed
motoxxxman is offline   Reply With Quote Quick reply to this message
Old 05-28-2006, 11:56 PM   #6
delude
Getting Comfortable
delude's Avatar
dont have an egr valve on the car.. its a jdm motor... tune up came when i put the motor in..all except for the cap and button and distributor.. but there was no problem when i had the other motor in the car... and the fuel filter.. injectors... and regulator have all been swapped out for new parts.. everything else checks out good as far as i know.. is there any easy way to check the fuel pump?
__________________
Old 05-29-2006, 02:12 AM   #7
motoxxxman
read the online manual. it tells how to test the fuel pump, for flow capacity. also, try to find a fuel pressure guage that can be used on our cars, and check the fuel pressure. proper pressure is also listed in the online manual, which is in the FAQ sticky
Old 05-29-2006, 09:35 AM   #8
PreLudePilot-X
Lude Boss
PreLudePilot-X's Avatar
PreLudePilot-X is on a distinguished road
maybe you should take the car to a trained professional?!
__________________
stop talking about what your going to do and just DO IT!!
I am The True, Original PreLudePilot-X
PreLudePilot-X is offline   Reply With Quote Quick reply to this message
Old 05-29-2006, 09:58 AM   #9
Bobnova
New title is new
Bobnova's Avatar
Location: Humboldt County (FAR northwest CA, on the coast)
Bobnova has a spectacular aura aboutBobnova has a spectacular aura about
Send a message via AIM to Bobnova
Are you using a JDM ecu to match your JDM manifolds?
If not, that may well cause the problem.
Manifolds, sensors, and ECU must all match, using the USDM ecu with JDM manifolds doesn't work well.
Check the fuel pressure too, high rpm bogging generally is fuel, as motox said.
__________________
--Bobnova '89 2.0SI 4ws(309k miles), '76 Triumph TR7 FHC (63k miles)
24 years of professional automotive experience, specializing in Honda/Toyota/Subaru.
Bobnova is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
