confused with h22a1 and h22a4 - Page 2 - Honda Prelude Forum : Honda Prelude Forums
Register FAQ Insurance Members List Calendar Mark Forums Read Auto EscrowAuto Loans
Reply
Thread Tools Display Modes
Old 03-20-2006, 11:58 PM   #26
illuded1
Newbie
illuded1 is on a distinguished road
Send a message via AIM to illuded1
the main diffence from h22a1 and h22a4 is h22a1 is close deck but is a stonger block and it has the manual tensioner for the time belt as to h22a4 is the weaker block. the pistons are coated with some type of cemical so it;s not abrasive to the cylinder walls and has the auto tensioner for the time belt which has fail causing the time belt go loose. best case if u go boost the 92-96 h22a1 is the ideal block. and if ur going all motor get the manual tentioner swap from a later modle h22.hope that gives you mor info about that.
__________________
illuded1 is offline   Reply With Quote
Old 03-21-2006, 12:38 AM   #27
JTC
Lude Addict
JTC's Avatar
JTC will become famous soon enoughJTC will become famous soon enough
Send a message via AIM to JTC
Prelude of the Month
Unhappy
Ugh... I really hate to do this, but I am in the mood tonight after reading 20 posts with more misinformation on it than I can stand...
To the last poster... Research before you spit out BS like that... NO h22 came with a manual tensioner... You are simply stupid when it comes to the engine in your car, no offense...
Heres the deal.. h22a1 is a USDM 92-96 motor as posted above. Its a closed deck design vs the h22a4 with the open deck design... The difference in decks is actually coolant passages.. Open deck has a coolant passage that essentially surrounds the entire "sleeve" and the closed deck has several ports designed to cool it.. The open deck should be more efficient on a stock motor and that explains the change to open deck... search for pics for more clarification if you need it...
All H series motors come with FRM sleeves.. FRM= Fiber reinforced Matrix(or material).. These sleeves are chemically injected and layed during casting. They are actually aluminum ALLOY sleeves instead of the common iron sleeve. They essentially have the same affect as a ceramic coated header(they dissipate heat better)..
The H22 series motors came with auto tensioners for timing belts... They have been known to be prone to failure.. Some last 200 miles, other last 90k miles... When the autotensioner fails, it causes the timing belt to become loose... Thus, it will slip teeth and bend valves... Many people do a conversion to a h23 manual tensioner to avoid this, especially those running aftermarket cams and SPRINGS...
Af far as motor specs... Very little changed between the h22a1 and the h22a4 which is somewhat depressing to me... The h22a1 is designated at 190hp and the h22a4 is designated at 195 (years 97-99) and 200 (00-01)(I may be off by 1 year on that)... The h22a is 200hp (jdm motor).. Compression for the h22a1 and h22a4 is 10:1.. h22a is 10.6:1...
The h22a1 is OBD1 as stated above, with exception of the 1996 model which is a obd2 compliant motor.. Several sensors are located in different places between the two models (ie. crank angle, etc.) The h22a1 has adjustable Ignition timing through the distributor...
Heres my take on this whole thing... Now, I have given you all the info you probably could care to have, and there is more out there...
HERE IS THE PROBLEM... California has very strict rules about engine swaps.. One of them states the engine must be as new or newer than the vehicle (someone correct me if I am wrong).. Does anyone see a problem with an engine swap and a BIG bodykit?
__________________
If you're into cars you must understand the golden rule: You have 3 words: Fast, Cheap, Reliable...
The problem is, you can only choose 2 of them.
Low 10's 1/4 mile in a prelude... Been There, Done That...
Breaking into the 9's.. Done Summer 09.
JTC Customs
Become a Facebook Fan:
JTC is offline   Reply With Quote
Old 03-21-2006, 01:12 AM   #28
Develitate
Newbie
Develitate is on a distinguished road
X2
Develitate is offline   Reply With Quote
Old 03-21-2006, 01:26 AM   #29
97 Lude VTec
Preludepower Member
97 Lude VTec's Avatar
97 Lude VTec will become famous soon enough
Send a message via AIM to 97 Lude VTec Send a message via MSN to 97 Lude VTec Send a message via Yahoo to 97 Lude VTec
hmm, point out my misinformation please
97 Lude VTec is offline   Reply With Quote
Old 03-21-2006, 02:09 AM   #30
Boosted521
Moderator
Boosted521 is on a distinguished road
nice post JTC.
sorry, but that was funny as hell
__________________
07 gpw s2000 - 07 gsxr1000 - 08 4runner
prev. - 03 s2000 / 03 350z perf. / 03 350z touring
03 cobra / 97 prelude / 06 cbr1000 / 03 cbr600 /
99 civic ex / 91 ford ranger
Boosted521 is offline   Reply With Quote
Old 03-21-2006, 06:12 AM   #31
illuded1
Newbie
more info to know. but for some reason i bought a jdm h22. i didn't have to swap over my manual tensioner coversion to my new motor. i took the used h22 block and put the my current head in the car on it from the blown motor in the car. any suggestion as to why the used h22 has a maual tensioner. i bought the motor at japannes engine depot.
__________________
Old 03-21-2006, 12:56 PM   #32
empireracing22
Newbie
empireracing22's Avatar
empireracing22 is on a distinguished road
Send a message via AIM to empireracing22
h22
h22a-jdm
h22a4-97-01
h22a1-92-96si
empireracing22 is offline   Reply With Quote
Old 03-21-2006, 01:32 PM   #33
Boosted521
Moderator
someone must have swapped it over before you bought it.
__________________
Old 08-05-2008, 05:19 PM   #34
cainofnorcal
True Luder
cainofnorcal's Avatar
cainofnorcal is on a distinguished road
Send a message via AIM to cainofnorcal
If its a fifth gen swapped to a a1 or an a how do you change the filter. I have an 88 with the h22a jdm swap the filter on it is in the back and as I recall the filter on a fifth gen is up top. is there clearance or was the filter set up swap
__________________
H22a installed and running. !!!220 ponies baby!!!
cainofnorcal is offline   Reply With Quote
Old 07-13-2009, 12:05 AM   #35
preludegurl98
Newbie
preludegurl98's Avatar
preludegurl98 is on a distinguished road
Send a message via MSN to preludegurl98
hey I having problems with my timing belts, the balancer belt is rubbing over my time belt
preludegurl98 is offline   Reply With Quote
Old 07-13-2009, 12:12 AM   #36
1sickasslude
Preludepower Member
1sickasslude's Avatar
1sickasslude will become famous soon enough1sickasslude will become famous soon enough
Rubbing Over?
For me(just me) to help, maybe a tad bit more information could be given out?
Is it a new timing belt, or an old timing belt? did it start recently?
__________________
Uh-60 Blackhawk Mechanic in Army.
1997 Prelude h22a4T-sold (Regret)
1989 Mk3 Supra Turbo-Sold(p.o.wire damage.s.)
2005 s2000-payments are a bitch
1sickasslude is offline   Reply With Quote
Old 07-13-2009, 12:17 AM   #37
preludegurl98
Newbie
its pretty new
Old 07-13-2009, 12:20 AM   #38
preludegurl98
Newbie
its pretty new
well it been making a noise for a cuople days, then yesturday timing belt broke when i turned the car on.
Old 07-13-2009, 12:24 AM   #39
matysik27
MATYSIKS HERE...
matysik27's Avatar
matysik27 is on a distinguished road
Send a message via AIM to matysik27
JTCdudeman definitely rep for you my man!
__________________
matysik27 is offline   Reply With Quote
Old 07-13-2009, 05:00 PM   #40
5thgenSH
Newbie
5thgenSH's Avatar
5thgenSH is on a distinguished road
Holy old thread batman. Also how did the topic go from h22a1 to h22a4 differences to worn timing belts?
__________________
5thgenSH is offline   Reply With Quote
Old 07-14-2009, 10:51 PM   #41
DfwBB6
Preludepower Member
DfwBB6's Avatar
DfwBB6 has disabled reputation
06 thread? FTL
__________________
the boost bug has bit you again... shut up and accept it
DfwBB6 is offline   Reply With Quote
Old 07-16-2009, 07:05 PM   #42
123me456you
Getting Comfortable
123me456you's Avatar
123me456you is on a distinguished road
need some help
i have a 90 honda prelude. it have a b21 in it, that burns oil like no other. i want to put in the h22. what do i need to find to make this work?
123me456you is offline   Reply With Quote
Old 07-16-2009, 10:18 PM   #43
Kronn 98SH
Prelude Aficionado
Kronn 98SH's Avatar
Kronn 98SH is a glorious beacon of lightKronn 98SH is a glorious beacon of lightKronn 98SH is a glorious beacon of lightKronn 98SH is a glorious beacon of lightKronn 98SH is a glorious beacon of lightKronn 98SH is a glorious beacon of light
Send a message via AIM to Kronn 98SH Send a message via Yahoo to Kronn 98SH
Search for the answer instead of posting your question in a thread that is completely unrelated. I would start in the 3G section.
__________________
1988 Prelude S - victim of an 80mph backflip
1991 Prelude Si - sold
1989 Accord DX - impounded
2006 CRF150F - sold
2006 YZ250F - sold
2006 S2000 (Laguna Blue Pearl) - purchased bone stock on 6/16/12
Kronn 98SH is offline   Reply With Quote
Old 07-14-2011, 05:42 PM   #44
My lude 93''
Newbie
My lude 93'''s Avatar
My lude 93'' is on a distinguished road
Originally Posted by 97 Lude VTec View Post
if i remember correctly... everything is the same, vtec engagement point is the same and so is redline.
Hey you seem to know alot about preludes, I have a 93'' Lude H22 with Vtec at how many RPMs does the vtec kick in.
My lude 93'' is offline   Reply With Quote
Old 07-14-2011, 05:46 PM   #45
Kronn 98SH
Prelude Aficionado
Kronn 98SH's Avatar
^ Worst nooblet first post for July 2011 goes to this guy.
__________________
2006 CRF150F - sold
2006 YZ250F - sold
Old 07-15-2011, 04:56 PM   #46
psud3ity
I am Prelude
psud3ity's Avatar
psud3ity is just really nicepsud3ity is just really nicepsud3ity is just really nicepsud3ity is just really nicepsud3ity is just really nice
The reason he probably swapped the older motor in is the same reason I did it.
You tack on another $800-$1200 to get a factory OBD2 h22. You can swap the required parts to make the motor OBD2 over from the old motor.
__________________
psud3ity is offline   Reply With Quote
Old 07-15-2011, 05:34 PM   #47
Kronn 98SH
Prelude Aficionado
Kronn 98SH's Avatar
For answering a question before noticing the thread was a 5 year old revival:
+rep to Psud3ity
__________________
2006 CRF150F - sold
2006 YZ250F - sold
Old 07-16-2011, 01:18 PM   #48
01ludeness
True Luder
01ludeness's Avatar
01ludeness will become famous soon enough
^lmao^ Funny how entertaining a FRIGGIN OLD post can be when new guys find a random thread to post their un-related questions to.. Then Kronn finds it...
__________________
01' H23a Vtec "Blue Top" Prelude, check out my build thread:
205whp and 168trq
01ludeness is offline   Reply With Quote
Old 07-16-2011, 05:34 PM   #49
nusdogg
Preludepower Member
nusdogg's Avatar
nusdogg is on a distinguished road
Lol.
__________________
The H22 wakes up the Accord in the same way a set of secondaries did to your father's Oldsmobile.
nusdogg is offline   Reply With Quote
Old 07-16-2011, 11:45 PM   #50
dre2day
Newbie
dre2day's Avatar
dre2day is on a distinguished road
pshhh
__________________
'99 Honda Prelude - Auto > 5spd *Completed*
Fidanza 8LB Flywheel
Exedy Clutch & Pressure Plate
Synchrotech Carbon Synchros
AEM CAI
TSUDO Cat Back Exhaust
Last edited by dre2day; 07-16-2011 at 11:46 PM. Reason: didn't notice it was old thread!
dre2day is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
vB.Sponsors
PreludePower Forums
