DIY: Individual Throttle Bodies (NEW update: Page 20) - Honda Prelude Forum : Honda Prelude Forums
Register FAQ Insurance Members List Calendar Mark Forums Read Auto EscrowAuto Loans
Reply
Thread Tools Display Modes
Old 02-28-2006, 07:18 PM   #1
98vtec
bangin' gears
98vtec's Avatar
98vtec is a name known to all98vtec is a name known to all98vtec is a name known to all98vtec is a name known to all98vtec is a name known to all98vtec is a name known to all
Prelude of the Month
since i will no longer be updating my thread on SHO, i will bring it here.
So here it goes from the beginning.
I had researched about this topic for a good 2 months before i decided that i definitely wanted to do it.
From there I purchased a set of 1300cc Suzuki Hayabusa ITB's from Golden_child on hayabusa.org for 175 shipped. They measure 46mm. I had an extra intake manifold from my motor swap and took that to a machine shop and had it cut.
So after doing a little more research i realized that i was going to need to have the throttles spaced in order to fit on the straight runner design. Lucky for me the Suzuki throttles are able to be taken apart.
I couldnt find anyone locally that i trusted to do the welding work and i dont personally have access to a welding machine so i knew i was going to have to find someone to do the welding for me. Little did i know, there was a little more welding involved than i thought.
I sent the flange and throttles off to a guy I met on honda-tech who has had experience in building these.
I dont have any pictures right now but i can tell you exactly what we are doing with them:
1st, the runners need to be welded onto the flange. Being extra careful not to mess up the stock injector ports so i wouldnt have any problems with the injectors sealing properly.
2nd, after the runners have been welded on...you have to determine how big of a spacer you are going to need to put between each throttle in order to line each one evenly to their parter runner. You will not be able to use the stock nuts and bolts that originally held the throttle together. You will need longer bolts due to the throttles being farther apart...duh!
3rd, since you are spacing the throttles apart..how do you put the throttle linkage together. In the picture below you will see the throttle linkage without any spacing done. This is the stock location:
so....how do you put them together once they are spaced? Simple, however amount of space is between the linkage, you weld a tab that connects them together.
The velocity stacks i have chosen to use are just absolutely SEXY. well, i think they are atleast.
These stacks run at $199 for the set. What i really like about them is that they are specifically engineered for hayabusa throttles. This immediately caught my eye.
Now....what about the TPS sensor? How am i going to fix that? What program am i going to be tuning with?
Well, fortunately for me I run a program called Crome which has full support for ITB tuning. It has a voltage scaler that allows you to run non factory TPS sensors and still be able to drive them as if it were a stock TPS. This is what you do:
1). Splice the harness from the suzuki TPS into the Honda TPS harness.
2).Get voltage readings from 0% and 100% throttle.
3).Write those numbers down and enter them in their respective place when you install the ITB tools plugin in Crome.
This voltage range of the suzuki tps is much less than that of the honda tps, which is the reason for this tool.
I will update with pictures and more details once i get them back. There are a couple other minor details that i will explain later.
__________________
Blake Barr
98 BB6 All Motor - Skunk2 / 4piston / Kaizenspeed / NepTune
92 EG H22 Hatch- Daily / Rosko Racing / NepTune / 32mpg
08 Nissan Armada - Tow Slut
98vtec is online now   Reply With Quote
Old 02-28-2006, 08:13 PM   #2
steveobb4
True Luder
steveobb4's Avatar
steveobb4 is on a distinguished road
coo
__________________
94 lude
was f22a1 auto
now Jdm H22a and 5spd
steveobb4 is offline   Reply With Quote
Old 02-28-2006, 08:19 PM   #3
97 Lude VTec
Preludepower Member
97 Lude VTec's Avatar
97 Lude VTec will become famous soon enough
Send a message via AIM to 97 Lude VTec Send a message via MSN to 97 Lude VTec Send a message via Yahoo to 97 Lude VTec
man, am i excited to hear/see those things in action... get this **** done... and good luck
97 Lude VTec is offline   Reply With Quote
Old 02-28-2006, 08:22 PM   #4
converge
Elite Member
converge is on a distinguished road
Send a message via AIM to converge
i'm excited about this. i'm very impressed.
__________________
converge is offline   Reply With Quote
Old 02-28-2006, 08:22 PM   #5
98vtec
bangin' gears
98vtec's Avatar
the last things to do once i get them back are to actually order the stacks and weld mounts onto the runners so i can mount the fuel rail. After that, the installation and tuning begins
__________________
Blake Barr
Old 02-28-2006, 08:31 PM   #6
BDoggPrelude
Future S2000 Owner
BDoggPrelude's Avatar
BDoggPrelude will become famous soon enough
Any estimations on when you will be finished? Also, is this setup street legal?
__________________
<-Colorado Prelude Owners Come Here!
BDoggPrelude is offline   Reply With Quote
Old 02-28-2006, 08:32 PM   #7
93PreludeSi
Preludepower Member
93PreludeSi's Avatar
93PreludeSi is on a distinguished road
Send a message via AIM to 93PreludeSi
i dont know why i thought u lived in NY but i though you did. Great write up and what year hyabusa were the ITBs off of. Do you know if hondata has that ITB program like crome? o yea and ur def gettin rep points for this.
__________________
props to black knight on the sig^^
<--what can i say they go together
93PreludeSi is offline   Reply With Quote
Old 02-28-2006, 08:33 PM   #8
98vtec
bangin' gears
98vtec's Avatar
it may not be legal in some states and i can almost gurantee that you wont pass emissions testing with them.
__________________
Blake Barr
Old 02-28-2006, 08:34 PM   #9
TopEndLude
Sleeper Needs Boost!
TopEndLude's Avatar
TopEndLude is on a distinguished road
Send a message via AIM to TopEndLude Send a message via MSN to TopEndLude
glad to see everything going a long so smoothly.
__________________
^^^^^^My POS^^^^
TopEndLude is offline   Reply With Quote
Old 02-28-2006, 08:35 PM   #10
BDoggPrelude
Future S2000 Owner
That's awesome.
__________________
Old 02-28-2006, 08:36 PM   #11
98vtec
bangin' gears
98vtec's Avatar
hahaha. I really dont know what year they are from. I'd like to say 2003. The only version of hondata that has itb support is the s300 unit.
__________________
Blake Barr
Old 02-28-2006, 08:36 PM   #12
98vtec
bangin' gears
98vtec's Avatar
That's awesome.
i dont have emission testing so its nothing to worry about
__________________
Blake Barr
Old 02-28-2006, 08:37 PM   #13
BDoggPrelude
Future S2000 Owner
Also, wouldn't you pretty much have to keep street driving minimal since you won't have any kind air intake filter anymore? Sorry for all the questions. This is really intersting.
__________________
Old 02-28-2006, 08:39 PM   #14
98vtec
bangin' gears
98vtec's Avatar
i will have filtration. There are many bike shops that sell socks that you can put over the velocity stacks and keep dirt and other road crap out of the motor. That way, if i ever wanna pop my hood, i can just pull the socks off and make them "look" better, lol.
__________________
Blake Barr
Old 02-28-2006, 08:42 PM   #15
fastkill
Deluded
fastkill's Avatar
fastkill is on a distinguished road
oh really thats pretty cool I always wondered how that worked.
fastkill is offline   Reply With Quote
Old 02-28-2006, 08:43 PM   #16
93PreludeSi
Preludepower Member
ill have to find out which one my brother has. I want to do this and i can do the welding myself its just the cutting part that i dont trust myself on and ill have to have a back up intake mani incase i mess it up. well it doesnt really matter i dont have an engine in my car i shouldnt be worried about this but ive been planning to do this for a while. when they are done you BETTER make a WOT pass video with no socks or anything i wanna hear that thing scream. if you dont ill come down to your fuckin emission less florida and make you do it at gun point
__________________
Old 02-28-2006, 08:43 PM   #17
fastkill
Deluded
fastkill's Avatar
by the way I always wanted to take a look at itb's on forced induction. I don't see that set up around too much. u have any pics
Old 02-28-2006, 08:44 PM   #18
98vtec
bangin' gears
98vtec's Avatar
there are lots of people who are crazy enough not to run socks or filters. But these are the same people that
A) hardly drive the car
B) It's a drag/Street car and it gets broken down for maintenance every "x" amount of miles or pulls.
or
C) too stupid to know any better
__________________
Blake Barr
Old 02-28-2006, 08:44 PM   #19
93PreludeSi
Preludepower Member
thats a redtarded amount of work and kind of pointless to have ITBs with FI
__________________
Old 02-28-2006, 08:45 PM   #20
93PreludeSi
Preludepower Member
well your gonna do a pass for me with no socks right??
__________________
Old 02-28-2006, 08:49 PM   #21
fastkill
Deluded
fastkill's Avatar
I seen a couple of pics on it @ a diff forum but never see to much discussion on it. But i guess it can be done.
Old 02-28-2006, 08:52 PM   #22
98vtec
bangin' gears
98vtec's Avatar
sure thing.
__________________
Blake Barr
Old 02-28-2006, 08:53 PM   #23
donalduck_69
Preludepower Member
donalduck_69's Avatar
donalduck_69 is on a distinguished road
Send a message via AIM to donalduck_69
You know, 2.2, for some reason, I don't think you'll have to make them "look" better. But, I have been wrong before. Oh, and I can't believe you let SHO see all the goods before us. Poo on you for that. But, now that you're here more, I guess I'll forgive you. Oh, and you rock. Just in case you weren't sure. Okey doke.
Nate
__________________
donalduck_69 is offline   Reply With Quote
Old 02-28-2006, 08:53 PM   #24
98vtec
bangin' gears
98vtec's Avatar
i've seen it done before but personally i would spend the money upgrading the turbo manifold. going from a log manifold to an equal length manifold is an instant 40whp.
__________________
Blake Barr
Old 02-28-2006, 08:56 PM   #25
93PreludeSi
Preludepower Member
anything can be done with time and money. it just matters if its worth it. having ITBs and boost dont really work together giving each cylinder its own throttle body gives it the opportunity to suck as much air as it wants because a manifold has 1, lets say 68mm TB, for all the cylinders to get air through. each TB on a ITB can be almost 50mm by itself. with boost air is being PUSHED into the engine so it doesnt matter how much air the engine is sucking because it has no choice but to take it in from all the pressure outside of the motor hence the name FORCED induction. really what im saying is ITBs let the cylinders breathe freely and boosting is like rape you dont have a choice its going in no matter what so you dont need to give each cylinder its own TB if it would be breathing on its own its being given plenty of air by force. thats my info of the day if anyone knows im wrong go ahead and correct me but thats my view on y boosting ITBs is pointless.
__________________
Sponsored Links
Advertisement
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
vB.Sponsors
PreludePower Forums
