Reload this Page HOW TO: H22 Auto Tensioner to H23 Manual Tensioner Conversion
Reply
Ads By Google
Thread Tools Display Modes
Old 11-30-2005, 12:18 PM   #1
98vtec
Gangster White Walls
98vtec's Avatar
98vtec is a jewel in the rough98vtec is a jewel in the rough98vtec is a jewel in the rough98vtec is a jewel in the rough
Write-up done by Scott Bryars
This seems to be a hot topic for the H22 owners out there. Here is a step by step "how to" conversion to the more reliable H23 (manual) style of tensioner. The H22a block used, is obviously a "mock-up", so don't be critical of the missing pieces. This conversion can be done in the car, but in this case it was done out of the car for illustration purposes only.
Parts list:
13404-PT0-004 - ADJUSTER COMP., BALANCER BELT
13415-PT0-000 - BRACKET, BALANCER BELT ADJUSTER
14510-PT0-004 - ADJUSTER COMP., TIMING BELT
14516-PT2-000 - SPRING COMP., TIMING BELT ADJUSTER
14521-P14-A00 - PLATE, ADJUSTER
90014-P14-A00 - BOLT, TIMING BELT ADJUSTER BASE
90015-PT0-000 - BOLT, TIMING BELT ADJUSTER SPRING
90016-PT0-000 - BOLT, TIMING BELT ADJUSTER
90140-P14-A00 - WASHER, PLAIN (11MM)
Here is a link for the parts list: http://www.hondaautomotiveparts.com/auto....%282%29
__________________________________________________ __________
This is a frontal and side shot of what the auto tensioner set up looks like with the timing belt cover, balance shaft crank pulley, balance shaft belt, and timing belt out of the way.
All of these thing will need to be removed to do this conversion.
Start by removing the auto tensioner pieces. These following pictures should be fairly self explanitory.
These following pieces will be removed from the h22 in this step and set aside for later use.
With the parts removed this is what it looks like.
This step, we will remove the troublesome auto tensioner.
With the auto tesioner gone, we will remove the rest of the tensioner mechanism. The following pictures should be self explanatory.
Now, with the complete auto tesioner mechanism removed, we are ready to add the manual tensioner parts.
This bolt and washer are what we start with. The factory washer is critical! It has a larger diameter than the block casting. This is a factory Honda part #90140-P14-A00 - WASHER, PLAIN (11MM), but for those of you who are lazy or pinching pennies, the diameter is 40mm and the thickness is 1.5mm If the wrong washer is used, improper alignment can occure as well as limited movement of the timing belt tensioner pulley.
These 2 pieces will be added next.
Add the timing belt tensioner pulley and check to see if it has full movement on its pivot.
Next we will install the balance shaft tensioner pulley. For this install, we will re-use the H22 part. The H23 part has a larger spacer that places it further out away from the timing belt pulley. I recomend using the H23 part (not shown), but with a few washers (used as spacers) the H22 pulley (pictured) can be used correctly.
If you are reusing the H22 part, MAKE SURE THE PULLEYS CLEAR EACH OTHER! This is a common mistake and can be catastrophic. When reusing the h22 balance shaft tensioner pulley, the pulleys must not touch! if you are using a h23 balance shaft tensioner pulley, there is no need to worry. it is already spaced properly.
Reinstall the balance shaft tensioner retainer.
Manual style tensioner in place completely. front and side views.
__________________
xXx Performance
South East Neptune and eCtune Tuner
-- UpRev / Haltech / AEM / DTAfast
98vtec is offline   Reply With Quote
Old 11-30-2005, 12:31 PM   #2
91preyludesi
Preludepower Member
91preyludesi's Avatar
91preyludesi is on a distinguished road
that is such a good writeup. glad it willl be somewhere it will last. *cough* sticky* cough** cough*. the collectiveracing link didnt work for me either. 2.2 did you do this already when you swapped??
__________________
"Falling Forward as she walks into the light"
R.I.P. 9/22/07 MISS YOU SIS!!
12/10/04 98 Honda Prelude
RMF header/ Greddy Evo2/ AEM v2 intake
91preyludesi is offline   Reply With Quote
Old 11-30-2005, 12:33 PM   #3
98vtec
98vtec's Avatar
Originally Posted by 91preyludesi
that is such a good writeup. glad it willl be somewhere it will last. the collectiveracing link didnt work for me either. 2.2 did you do this already when you swapped??
yep. These pictures should never go down.....atleast unless SHO goes down
__________________
xXx Performance
Old 11-30-2005, 12:50 PM   #4
prelude1897
prelude1897's Avatar
prelude1897 has a spectacular aura aboutprelude1897 has a spectacular aura aboutprelude1897 has a spectacular aura about
Send a message via AIM to prelude1897
Prelude of the Month
This should be a sticky if it isn't already...I've already done this conversion myself
__________________
97 Prelude-wrecked
00 Prelude-daily driver
99 Prelude-RHD Prelude
98 Prelude-Parts Car-SOLD
RHD Conversion
Retrofit Service PM me or visit my myspace page
prelude1897 is offline   Reply With Quote
Old 11-30-2005, 06:54 PM   #5
Boosted521
Moderator
Boosted521 is on a distinguished road
it's going in the resource thread. thanks blake
__________________
07 gpw s2000 - 07 gsxr1000 - 08 4runner
prev. - 03 s2000 / 03 350z perf. / 03 350z touring
03 cobra / 97 prelude / 06 cbr1000 / 03 cbr600 /
99 civic ex / 91 ford ranger
Boosted521 is offline   Reply With Quote
Old 11-30-2005, 07:38 PM   #6
Mikeyslude
Guest
Posts: n/a
nice write up and pics. please sticky this.
i've done the conversion here as well but it was no where near as easy as it looks because my engine was still in the car.
Old 05-15-2006, 05:41 PM   #7
Dem1K
True Luder
Dem1K's Avatar
Dem1K is on a distinguished road
Send a message via AIM to Dem1K
so that parts list is just for the swap only, right? Cause I need to supposedly replace my auto-tensioner (which means I need to replace the timing belt and water pump). Are those not included in that parts list? I need to know all the parts in order to get all this fixed.
btw, awesome write-up
__________________
Dem1K is offline   Reply With Quote
Old 05-16-2006, 07:47 AM   #8
Honda4Life
Honda4Life is a jewel in the roughHonda4Life is a jewel in the roughHonda4Life is a jewel in the rough
I believe that is what you need in place of the auto tensioner.
Honda4Life is offline   Reply With Quote
Old 05-16-2006, 12:39 PM   #9
xPhax
Newbie
xPhax is on a distinguished road
Is the h23 balance shaft tensioner pulley included in the parts list?
xPhax is offline   Reply With Quote
Old 05-16-2006, 01:43 PM   #10
Dem1K
True Luder
Dem1K's Avatar
it looks like there is a timing belt in there also? Is that the same belt that I need replacing when doing this service? Looks like I would need those parts, and then the water pump?
__________________
Old 05-31-2006, 02:41 PM   #11
lambolude
Stop typing and go DO it!
lambolude's Avatar
lambolude is on a distinguished road
Send a message via AIM to lambolude
how about a specific complete parts list including both h23 tensioners and both belts?
__________________
sig by: Black Night
Prelude.....an introductory performance, action, or event preceding and preparing for the principal or a more important matter
Check out my sick ass lude
lambolude is offline   Reply With Quote
Old 05-31-2006, 04:58 PM   #12
preludesh2000
Donating Member
preludesh2000's Avatar
preludesh2000 is on a distinguished road
is there any kind of maintence to a manual tensiioner...such as tighting it ever so often....
or is that just the name itself "manual tensioner"
does it self tighten also ???...with the spring
__________________
2000 sh lude
93 rx7 touring
R.I.P....98 black sh lude
preludesh2000 is offline   Reply With Quote
Old 06-01-2006, 07:06 AM   #13
JLude
Idiotic Thread Locker!
JLude's Avatar
JLude is a jewel in the roughJLude is a jewel in the roughJLude is a jewel in the roughJLude is a jewel in the rough
Send a message via AIM to JLude
Thanks bro! I'll be using this when I change my timing belt at 85K
__________________
Building your custom HID Projector RETROFITS!!! PM FOR DETAILS.
'90 Si 4WS, 2002 SSM S2000, 2000 Tacoma V6 4x4 TRD, 2006 Yamaha FZ6, '92 Civic LX 4dr
JLude is offline   Reply With Quote
Old 10-23-2006, 09:52 AM   #14
Cruiserdude
Got Koni?
Cruiserdude's Avatar
Cruiserdude will become famous soon enoughCruiserdude will become famous soon enough
Send a message via AIM to Cruiserdude
Yeah, just looking through the resource thread here and I echo PreludeSH2000's question: Does the manual tensioner ever need re-adjustment? I was under the impression that it does not, but then a local mechanic friend of mine (who really knows his shit) said that as far as he knows, a manual tensioner would have to be re-adjusted periodically.
__________________
-Andrew-
'01 Premium White Pearl Type SH-ATTS Baby!!!
Rep Points Accepted Here and All Participating Locations of Cruiserdude!!!
Have a Honda? Don't know how to tune it? Try
for all your tuning needs!
Cruiserdude is offline   Reply With Quote
Old 12-19-2006, 12:08 PM   #15
Cruiserdude
Got Koni?
*bump* Still wanting to know for sure, as I'm about to do this. I've heard different things from different people, all of them very reliable sources. Do I ever have to readjust a manual tensioner after initial installation, or not?
__________________
-Andrew-
Old 12-19-2006, 12:33 PM   #16
98vtec
98vtec's Avatar
i dont see the need in retightening unless something out of the ordinary happens. The belt will eventualy stretch enough to where you may need to retighten, but i dont see that happening anytime soon with a new belt.
__________________
xXx Performance
Old 12-19-2006, 01:30 PM   #17
Honda4Life
My question is, What is part #14521-P14-A00 Plate/Adjuster used for? I have helped 2 different people do the swap and never been able to figure out where it goes.
It is listed as one of the parts needed, but it not used in your write up either. I have seen other people on other sites list it in swap kits for the H22 also.
Thanks,
Mike
mnhondaparts@gmail.com
Old 12-19-2006, 01:31 PM   #18
Cruiserdude
Got Koni?
Thanks,
Mike
That's the A-bracket you told me about?
__________________
-Andrew-
Old 12-19-2006, 01:48 PM   #19
Honda4Life
Yes sir it is the one we discussed on the phone.
Old 12-19-2006, 07:45 PM   #20
gfresh86
Lude Dude
gfresh86's Avatar
gfresh86 is on a distinguished road
another question is how would u be able to readjsut the tensioner? would you have to take apart the timing covers again?
gfresh86 is offline   Reply With Quote
Old 04-15-2007, 12:28 PM   #21
cinci-91-H
Dunkel Weisse
cinci-91-H's Avatar
cinci-91-H will become famous soon enough
In Pic #18 & #19 there is shown a small threaded "pivot shaft" that is shown to be threaded into the block. I am doing this conversion and ordered the parts list posted here. I received a small plate not viewed in any of these pics. It appears to bolt to block right where the auto tensioner bolted, the bolt pattern is the same. That "pivot shaft" did not match the threads on my block where it is shown in #18 & #19 being installed. It did however fit the bracket (bolted where auto tensioner was), I believe that this is how you lock the pulley into position on a h23. On this application, however, I am finding that the belt is already pretty tight at full loosen on this bracket.
My question:
Is there an additional part # that I need to order to get the piece from #18 & #19 ?, I think I need something there for the timing tensioner pulley to pivot on.
anyone follow what I'm saying ?, I'll try to get some pics and put them up.
__________________
___________________
"Keep me movin ... over 50 ...keep me groovin ... just a hippy gypsy ... come on move now"
___________________
cinci-91-H is offline   Reply With Quote
Old 04-15-2007, 01:38 PM   #22
daluder
Preludepower Member
daluder's Avatar
daluder is on a distinguished road
anyone wanna do this for my lude??
__________________
2008 World Series Champions Philadelphia Phillies
holy sh*t..holy sh*t..
daluder is offline   Reply With Quote
Old 04-16-2007, 05:52 AM   #23
Lil_Black_Lude
Lude Addict
Lil_Black_Lude's Avatar
Lil_Black_Lude is on a distinguished road
Send a message via AIM to Lil_Black_Lude
This will probably sound stupid..but what is this for?
Lil_Black_Lude is offline   Reply With Quote
Old 04-16-2007, 07:49 AM   #24
1fastlude
Preludepower Member
1fastlude's Avatar
1fastlude has a spectacular aura about1fastlude has a spectacular aura about
Send a message via AIM to 1fastlude Send a message via Yahoo to 1fastlude
Hey Mike(Honda4life) can u give me an quote on how much i'd be lookin at for all the parts for the conversion?
Thanks, Kevin(1fastlude)
1fastlude is offline   Reply With Quote
Old 04-16-2007, 11:20 AM   #25
cinci-91-H
Dunkel Weisse
cinci-91-H's Avatar
Roughly $200
__________________
___________________
___________________
Reply
Bookmarks
  • Submit Thread to Digg Digg
  • Ads By Google
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b21a1 car motivational posters convertible prelude dashboard paint edge2lyfe view profile floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22a4 specs h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen how to text your girlfriend hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews pcv valve symptoms power prelude prelude prelude convertible prelude forum prelude forums prelude power preludepower preludepower.com projector retrofit racing hart cp-035 rattle can paint job song suggester sweet things to say to your girlfriend in a text sweet things to say to your girlfriend over text sweet things to text your girlfriend things to text about things to text your girlfriend what to text your girlfriend www.preludepower.com
    Thread Tools
    Display Modes
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Forum Jump
    KickItBack = Cash Back
    Google
    vB.Sponsors
    PreludePower Forums
