| Register | FAQ | Insurance | Members List | Calendar | Auto Escrow | Auto Loans |
Thread Tools | Display Modes |
#1 |
i replaced both my front and rear motor mounts this january with brand new mounts from dealership. and for the past 2 days i have been metal-metal contact/grinding whenever i put my car in rear and try to back out. i had a mechanic drive me car and he says that my motor mounts r shot.
i think i am done with this car. the laundry list does not stop. i needs a new motor (b21a1 is gone), new tranny (need to swap auto-> manual), rear wheel bearing hub, control arm bushing, brake master cylinders and many more. if i can figure out a way to afford another car right now, i am ready to get rid of this one. -------------------------------------------------------------------------- so i got another mechanic to look over the grinding issue. mind u i eliminated the motor mounts because i checked them and they r in pretty new condition. this guy said that it sounds like my tranny is going south. i might need a new auto tranny. offcourse on monday he will check it more carefully and determine what needs to be done and provide me an estimate. now the thing is i do not want it to be tranny issue, but if it is, i want to replace my auto with a manual. how much is the cost estimate in either case. could someone pls be kind to point that out. Last edited by paramthegreat; 09-03-2005 at 07:35 PM. Reason: Auto Tranny Needs replacement |
#2 |
16-Bit Era!
Just look and see if they are broke yourself, start the car pop the hood and turn the TB rotor to rev the engine, if it rocks back and forth a ton when you rev it up and let off, they are probably broke. You should be able to see little cracks in the rubber of the mounts too.
#3 |
Preludepower Member
Your going ot have the same problems with any car that you can afford that is about the same price as our ludes.
Common wear and tear 14 years of it. If you have the time and patience you really never need to buy another car unless it has Massive dmg. But even then. I hear ya that your frustrated I have had many a time like that. But think of it this way replace the mounts again if they need it then maybe the bushings and get a JDM B20A and your set for another 10+ years. Also replace Clutch flywheel and half shafts just to be safe. But Meh If you sell it I will understand but look into how much it will cost first. Labor is a Biotch
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#4 |
Lude Addict
Motor mounts don't have a specific service life. They last indefinately. At least mine have. Replace them when they wear out. Thats it.
__________________
[SIGPIC][/SIGPIC] |
#5 | |
my symptons - pls diagnose
#6 |
bump
#7 |
Preludepower Member
checked your axles? ball joints?
__________________
~Chris To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Just call me the Thread Locker. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
