engine revs up and down by itself?!?! - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 12-07-2004, 03:14 PM   #1
myaccord7
Newbie
myaccord7 has disabled reputation
i just got the car. its an 89 prelude 5speed. when its in netural it revs up and down without my foot on the gas. only does it in netural. do these cars have a throttle sensors? or would it be the egr valve? thanks
zach
__________________
98 H22 Turbo'ed Prelude, and 89 Accord 4door.
myaccord7 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-07-2004, 03:21 PM   #2
Slipslap
Unactive
Slipslap is on a distinguished road
vacuum leak, fast idle valve, cold idle temp sensor.
__________________
looking for a 3rd gen engine
READ this about engine ADDITIVES
Turbo manifolds for sale
Your car must be fast, cause you were flying when I passed you!
Slipslap is offline   Reply With Quote Quick reply to this message
Old 12-07-2004, 06:30 PM   #3
sleeperlude
Lude Addict
sleeperlude has disabled reputation
Send a message via AIM to sleeperlude
It could be any of those, do you live in the north where it just got cold? I seriously doubt the egr valve has anything to do with it
sleeperlude is offline   Reply With Quote Quick reply to this message
Old 12-07-2004, 07:39 PM   #4
metalman
Lude Addict
metalman has disabled reputation
Send a message via AIM to metalman
bleed the coolant, that could also cause it
metalman is offline   Reply With Quote Quick reply to this message
Old 12-07-2004, 08:05 PM   #5
dano
Prelude Aficionado
dano has disabled reputation
If the fluctuation is in the 700-1,000 rpm range it may be easy to fix. You will find a slotted set screw at the top of the throttle body facing towards where the air filter elbow is attached. The fluctuation is caused by the idle mixture being too lean. Turn the screw (with the engine running at idle) clockwise to enrichen the mixture. This screw is call an "Idle Speed Adjustment Screw" Actually, it adjusts the idle speed, but, by leaning out or enriching the idle mixture and not by moving the throttle plate.
If the fluctuation is at higher rpms like 1,500-1,700, this will not work !!
__________________
dano is offline   Reply With Quote Quick reply to this message
Old 12-07-2004, 10:48 PM   #6
smokescreen
Preludepower Member
smokescreen has disabled reputation
Prelude of the Month
Of course a Leaky EGR valve can cause this. Thats the first thing I would check. Ive seen this happen many times....
smokescreen is offline   Reply With Quote Quick reply to this message
Old 12-08-2004, 01:21 AM   #7
Bobnova
New title is new
Bobnova's Avatar
Location: Humboldt County (FAR northwest CA, on the coast)
Bobnova has a spectacular aura aboutBobnova has a spectacular aura about
Send a message via AIM to Bobnova
Dano is right about most of that, but the screw doesn't control idle mixture, it's basicly a calibrated vacuum leak, allowing some extra air into the intake manifold, which the computer detects via map sensor, just like it would detect air getting in any other way, and adds fuel to match.
However, the computer doesn't like the idle being that high, and tries to turn it down via the idle control motor, and goes into a crazy loop.
If the fluctuation is 1500-2000(ish, very ish, but higher then 1000-1300) it's a largeish vacuum leak, either from a vacuum line or from the fast idle valve.
If you do a search for fast idle valve you should find recent instructions on how to deal with that.
__________________
--Bobnova '89 2.0SI 4ws(309k miles), '76 Triumph TR7 FHC (63k miles)
24 years of professional automotive experience, specializing in Honda/Toyota/Subaru.
Bobnova is offline   Reply With Quote Quick reply to this message
Old 12-08-2004, 02:59 PM   #8
cowsnuker
Moderator
cowsnuker is an unknown quantity at this point
Send a message via AIM to cowsnuker
I had this problem before doing my engine swap... was my EGR.
Now I have a rev that's somewhat stable, it moves about a cm on the tach.
__________________
If you got a K20 into the lude I will seriously ask for you hand in marriage HA! Man those things are insane.
rofl@that noob.
cowsnuker is offline   Reply With Quote Quick reply to this message
Old 12-08-2004, 05:36 PM   #9
supeludecoupe
Newbie
supeludecoupe's Avatar
supeludecoupe has disabled reputation
Mine moves a little also. It seems to do it when it's warm but hasn't really been driven too much. It goes away when it's nice and warm. I've been wondering if it was cold idle temp sensor but it does it when it's warm but not hot so I'm still not sure. I am going to check some of the things mentioned here but it sounds like here and the other "bouncing idle" threads are more obvious than my slight rough idle.
__________________
supeludecoupe is offline   Reply With Quote Quick reply to this message
Old 12-08-2004, 06:34 PM   #10
supeludecoupe
Newbie
I have also looked into all the fixes listed in various posts and none seem to be my minor trouble...or maybe it is a vacuum leak that's really small.????
__________________
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
