Ok I know some of guys had no clue of what I was talking about when I brought this topic up several months ago. PVC pipe?? Whats that?? so hear you go: I could not find a socket deep enough with the proper diameter. I even have a 1" drive socket set. Just nothing deep enough for the crank. So I went to the hardware store and found the Perfect Oil pump seal install tool. A 1"1/4 pvc pipe coupler that is 2"1/8 long. The white one was too short but the gray one (for elictrical pipe I believe) was just what the doctor ordered. With this "coupler" and a washer I bought (2" and hair more/wide). The inside diameter of washer is a 1/32" bigger than 3/4" at 13/32". I was able to use the stock crank pulley bolt and press/drive in the oil pump seal effectively and evenly. Its simple, Its cheap and it works. For the cam seals I just used a large socket and bought a longer bolt the same size as the cam gear bolt.
Oil Pump Front Seal / Front crank seal tool:
1 1/4" PVC Coupler. 2 1/8" Long
Washer: 2" O.D. 13/32 I.D. Hole (just over 3/4")
or: IE 50mm O.D. 21mm I.D.
Stock Crank Pulley bolt
Like the degreasing job??
