clutch pedal switch ?? - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 08-05-2004, 11:37 PM   #1
ludenewbie
Unactive
ludenewbie is on a distinguished road
Hi again.
I have another desire - I want to 'wire out' the nasty clutch switch
that presumes folks are too stupid to depress the clutch when it
is time to crank the engine - anybody else ever do this ?
Is there an easiest way to jump it out ??
Thanks !
mark
ludenewbie is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-06-2004, 02:35 AM   #2
Jump
Prelude Aficionado
Jump is on a distinguished road
Send a message via Yahoo to Jump
Without looking at the wiring diagram, my first guess would be to just remove the switch and tie wrap it up under the dash in case you ever want it again.
__________________
Jump is offline   Reply With Quote Quick reply to this message
Old 08-06-2004, 07:51 AM   #3
ludenewbie
Unactive
Doesn't this switch actuate when the pedal is
pushed down - i.e.: it needs pressure to do it's
thing ??
mark
Old 08-06-2004, 10:23 AM   #4
BostonLude
Lude Cray
BostonLude has disabled reputation
Send a message via AIM to BostonLude Send a message via MSN to BostonLude
I think a push bottom from radio shack my work. The thing about putting the clutch in to turn it on is that you remeber not to launch your vehicle if it is in gear.
__________________
If it isn't a Prelude Why buy it
BostonLude is offline   Reply With Quote Quick reply to this message
Old 08-06-2004, 12:11 PM   #5
dazy_too
Lude Dude
dazy_too has disabled reputation
Mine went bad, I ended up replacing the starter thinking the starter was bad. Then, I had to run a wire to bypass the clutch switch.
dazy_too is offline   Reply With Quote Quick reply to this message
Old 08-06-2004, 12:17 PM   #6
hondaprelude88
The Ruler of PreludePower
hondaprelude88's Avatar
hondaprelude88 will become famous soon enough
Mine never had one.
__________________
hondaprelude88 is offline   Reply With Quote Quick reply to this message
Old 08-06-2004, 12:45 PM   #7
Kalm_Traveler
穏やかな旅行者
Kalm_Traveler's Avatar
Kalm_Traveler will become famous soon enough
yeah mine never had one either. Can anyone confirm that possibly 88-89's didn't come with the clutch safety switch? I do have the other switch that tells the car the clutch pedal is all the way released (otherwise cruise control wouldn't work), but yeah like ^^^he^^^ said, my car never had a clutch safety switch; there's no wiring for it, no spot where it looks to have been or anything.
Kalm_Traveler is offline   Reply With Quote Quick reply to this message
Old 08-06-2004, 01:25 PM   #8
ludenewbie
Unactive
'89 has it - because mine has it !
Dazy_too, where did you run the jumper ??
mark
Old 08-06-2004, 05:21 PM   #9
dazy_too
Lude Dude
I ran a high current cable (about a 10 or 12 guage wire) from just behind the steering wheel cover inside the car, to the Engine compartment on the passenger side to just past a connector that connects to the starter.
The connector in the engine bay is on the passenger side just past the shock tower towards the front of the fuse box. It's a big about one inch rectangular connector that is covered with a yellowing clear plastic cover.
Look for I believe it is the White with Black Stripe cable, at both ends; from the back of the steering wheel cover to the engine compartment. No more than 12 feet of cable needed.
Old 08-06-2004, 08:20 PM   #10
OMega
I am Prelude
OMega's Avatar
OMega has disabled reputation
My switch went bad also. I just bypassed the clutch relay with a paper clip.
OMega is offline   Reply With Quote Quick reply to this message
Old 08-06-2004, 09:05 PM   #11
larrybpsu
Elite Member
larrybpsu has disabled reputation
Just a heads up that if you bypass the clutch switch, your cruise control will probably stop working. The cruise is wired to disengage when you step on the clutch.
If you use your cruise, bypassing this switch may be a bad idea.
Larry
__________________
LarryB
88 S 4WS (Blue): 1st place 3g NPM 2004 2nd place 3g NPM 2006
88 Si 4WS (Yellow): My brother's car - My prelude beater! LOST...now.
larrybpsu is offline   Reply With Quote Quick reply to this message
Old 08-07-2004, 01:24 AM   #12
netfreak
Elite Member
netfreak has disabled reputation
Send a message via ICQ to netfreak Send a message via MSN to netfreak
cruise control should also disengage when you push the brakes
__________________
88 Prelude (sold)
92 Civic B16A (parted)
89 CRX - GSR swap in progress
netfreak is offline   Reply With Quote Quick reply to this message
Old 08-07-2004, 10:16 AM   #13
ludenewbie
Unactive
My understanding is that there are 2 clutch
switches - and in my car the starter won't engage
unless I have the clutch absolutely RAMMED into
the floor; whereas the cruise control disengages
with a gentle touch to the clutch pedal - which tends
to make me think there are 2 switches for sure.
Does anyone know more about this ?
mark
Old 08-07-2004, 01:26 PM   #14
1badlude
Getting Comfortable
1badlude has disabled reputation
im almost certian that there are 2 switches bc the clutch must be down all tha way to start (like pushing in a button) then when the clutch is let back out (like pushing a button) it will engage the option for cruse control because if tha cruse is set and u push tha clutch pedal it will disengage the cruse thearfore leading me to beleive there are 2 switches, 1 for when its pushed all tha way in and 1 for when its let all tha way out
__________________
If you are nice i will cean the dust off car next lap past you
1badlude is offline   Reply With Quote Quick reply to this message
Old 09-11-2006, 03:23 PM   #15
three11jeff
True Luder
three11jeff's Avatar
three11jeff is on a distinguished road
Send a message via AIM to three11jeff Send a message via MSN to three11jeff
Prelude of the Month
I'm researching this because I've run into the same problem and I'll post what I found.
The below picture is a clutch pedal for a 89S but the wiring is for a 88Si.
This picture is of the 88Si clutch pedal.
This picture is taken of a 89 Prelude Helms manual.
This just leads me to believe that the 88 preludes did not have the switch and 89 preludes did. The ONE clutch wire out of 88si wiring harness does not fit either of the 89s pedal switches. So... I will try and pull the lower switch from the 88si pedal to replace the 89s switch. Nothing will be pluged into the top switch. This should work, Right!?
__________________
1 Peter 1:3
(National Prelude Meet 2009)
three11jeff is offline   Reply With Quote Quick reply to this message
Old 09-11-2006, 04:37 PM   #16
88si--
Guest
Posts: n/a
my 88 si does not have a safety switch for the starter , only for the cruise, which i dont use anyway.and it came without the switch i didnt take it out or alter it.
Old 09-11-2006, 04:45 PM   #17
Run_Away
Lude Boss
Run_Away's Avatar
Run_Away will become famous soon enough
That's right, 88s didn't have the switch but 89s did.
I had an issue with that getting my '89 safetied when I did the auto->manual swap.
__________________
-Ben
Run_Away is offline   Reply With Quote Quick reply to this message
Old 09-11-2006, 04:55 PM   #18
88si--
Guest
Posts: n/a
saying this i could definatly be wrong but in my teg. i just zip-tied the little button thing back and bam, end of that problem........would this work on the lude????????
Old 09-12-2006, 01:46 AM   #19
alanoneil
Ludacious
alanoneil's Avatar
alanoneil is on a distinguished road
Send a message via AIM to alanoneil
There are indeed two clutch pedal switches on 89 ludes. One that is always on until you press the clutch at all (for cruise control), and one that is never on until you press it all the way to the floor. You can just unplug the cable from the second switch and jumper it with a paperclip or piece of wire and your car will happily start in gear. I did it not for annoyance purposes, but because you never know when you'll need to crank those few extra feet on the way to the gas station...
__________________
'89 Prelude 2.0Si 4WS, 141k mi. Love that B20A5!
SuperPro urethane bushings, Ground Controls, and Koni struts.
alanoneil is offline   Reply With Quote Quick reply to this message
Old 08-10-2007, 07:52 PM   #20
amar67
Getting Comfortable
amar67's Avatar
amar67 is on a distinguished road
clutch switch
Please help! car won't start. battery and alt checkout fine so I'm pretty sure it's either the clutch safety switch, ignition switch or the starter. there were no indications of the starter going bad so I'd like to start with bypassing the clutch switch. anyone know where this switch is? I found the cruise switch and the stopper is missing so I guess after I fix that the cruise will work again!!! we were able to push start the car and get it home so I know all else is fine!
amar67 is offline   Reply With Quote Quick reply to this message
Old 08-10-2007, 09:00 PM   #21
Run_Away
Lude Boss
Run_Away's Avatar
What year is the car? 88s don't have the clutch safety switch.
__________________
-Ben
Old 08-11-2007, 04:20 AM   #22
amar67
Getting Comfortable
amar67's Avatar
it is an 89s. I'm pretty sure it's not getting juice to the starter. checked battery.
Old 08-11-2007, 07:01 AM   #23
amar67
Getting Comfortable
amar67's Avatar
will not start
ok, just eliminated the starter as the problem by connecting the solenoid directly to the battery and the car fired right up! so, I really need some help finding the clutch pedal switch for starting (not cruise) I see the cruise switch but no other switch. where is this switch???
thanks in advance!!!
Old 08-11-2007, 10:27 AM   #24
indy7_emt
indy7_emt is on a distinguished road
I had the same problem a while back with my 91. Easiest fix is a starter button. Autozone sells a 60amp enclosed starter button. Run a wire from starter to button and another wire from one of the hot wires in your steering column. Make sure you use a wire in column that is only hot when the key is on. I've had this set up for about three months and have had no issueswith it. Besides.... shouldn't a sports car have a push button start?
indy7_emt is offline   Reply With Quote Quick reply to this message
Old 08-11-2007, 11:54 AM   #25
elmotive
Ludacious
elmotive's Avatar
elmotive is on a distinguished road
Send a message via ICQ to elmotive
I've never seen that top switch on EDM ludes. Whatever year model. Only the lower ones on cars with cruise control. Maybe it's USDM only?
__________________
1991 PRELUDE B20A9 D2A4 2.5 INCH CUSTOM MADE MANDREL BENT EXHAUST AC CC LEATHER POWER DOOR LOCKS-WINDOWS-SUNROOF-MIRRORS ADJ HEADLIGHTS POWER STEERING 215/40-16 2WS BLACK CENTER ARMREST FRONT AND REAR CROSS DRILLED ROTORS HEATED AND ELECTRIC FOLDING MIRRORS HEATED FRONT SEATS OEM REAR BOOT LID WING OEM FRONT AND REAR LIP
x2 elmotive we're makin a team today! your stealing the words right out of my mouth, its making my life way to easy haha
elmotive is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
