Reload this Page Resource For 5th Gens (TSB's/Parts/Sites/Reviews)
Closed Thread
Ads By Google
Thread Tools Display Modes
Old 06-19-2004, 05:34 PM   #1
charliec
Preludepower Member
charliec's Avatar
charliec is on a distinguished road
Post Resource For 5th Gens (TSB's/Parts/Sites/Reviews)
COMMON FIXES/MAINTENANCE
Official "water leaking into car" help video - courtesy of Kevin01SH
Reference
5th Generation Prelude Pictures
5th Gen Technical Service Bulletins
5th Gen Exhaust Pictures
5th Gen Exhaust Clips - courtesy of Hprelude5r
5th Gen Bulb Sizes - courtesy of preludesh2000
5th Gen Gear/MPH Graph - courtesy of Boosted521
5th gen Service manual
5th gen Service manual Torrent Files - courtesy of Lil_Black_Lude
ATTS Friendly Modifications - courtesy of Cruiserdude
About Check Engine Lights - courtesy of irolllow
Basic Info On All H22 Engines/Transmissions - courtesy of 98vtec
Beginners Guide To Engine Modifications - courtesy of 98vtec
Brake Myths Resolved - courtesy of irolllow
Combustion, Timing, Cylinder pressure and Knock Article - written by Jeff Evans linked courtesy of 98vtec
Discussion: Obd2 to Obd1 Conversion - courtesty of 98vtec
Guide to buying Tools - courtesy of irollow
Header Design Basics - courtesy of irolllow
How Does The AEM V2 Sound?
How to tell if you have a SH model 5th gen - Courtesy of lilredlude
Ignition Timing Tech - courtesy of 98vtec
Quick Reference To Helms Manual Index - courtesy of Boosted521
Spark Plug Information - courtesy of irolllow
Understanding Camshafts - courtesy of 98vtec
Understanding ECU Tuning - Courtesy of irollow
Vehicle Wiring Information for the 5th Gen - courtesy of Boosted521
Water/Methanol Injection 101 - Courtesy of Cruiserdude
Quick Reference: Nuts, Bolts, Sockets, torque specs- courtesy 98vtec
Picture guide to locating EGR, IAC, PCV Valves- courtesy of KManz
EGR Port Plug Part numbers - courtesy of Honda4Life
Spring Rate Comparisons - courtesy of YellaLude
Extended wheel studs that don't require modification - courtesy of EBPludeSH
5th Gen Prelude Electrical Troubleshooting guide - courtesy of Kronn 98SH
5th Gen bulb sizes - courtesy of Kronn 98SH
Prelude Tranny Codes and Gear ratios - courtesy of Kronn 98SH
H Series Engines Info Chart - courtesy of Kronn 98SH
Speedo/Tach Chart - courtesy of Kronn 98SH
5th Gen Models (worldwide) - courtesy of Kronn 98SH
Hot Threads/Articles/Links (good info)
HID discussion
DIY Individual Throttle Bodies
Sh or base? - courtesy of lilredlude
Intake Manifolds Explained, Compared, and Contrasted - courtesy of JTCdudeman
Type S strut bar compatibility - Type S strut base part no. courtesy of netzyo98
SS Automatic Transmissions 101 - link courtesy of borcth
LINK: Comparison: 97-98 header vs 99-01 (the extra 5hp myth) - courtesy of qualude2250
Variable Valve timing (VTEC): What is it, Who needs it? - courtesy of Cruiserdude
Global Accord specs (Prelude related)- courtesy of Cruiserdude
Guide to Valve Adjustments + extra
5th gen Fact Book
Header discussion - courtesy of nordicmist2
WRITE-UP/RESOURCE THREAD: 5th gen auto to 5spd SWAP - courtesy of alpinefr3ak
HOW TO's
HOW TO: 4th gen shift assembly into 5th gen - courtesy of 98vtec
HOW TO: 5th Gen Projector Retrofit - courtesy of Brodie from PO.com and Boosted 521
HOW TO: 5th Gen Retrofit- Courtesy of Jlude
HOW TO: Painting the Side Skirts and Rear Lip on a Base Model - courtesy of pIOUs from PO.com and Boosted521
HOW TO: Compression Test - courtesy of Boosted521
HOW TO: Diagram for Using Turn Signals as Fog Lights - courtesy of sinecter
HOW TO: Changing LED Colors in Climate Control - courtesy of pIOUs from PO.com and Boosted521
HOW TO: Changing the Color of the Clock - courtesy of Boosted521
HOW TO: Changin Color of the Ignition LED - courtesy of Boosted521
HOW TO: Clutch and Flywheel install with PICS - courtesy of 98vtec
HOW TO: S2000 Push Button Install - courtesy of Boosted521
HOW TO: Replacing wheel bearings - courtesy of irolllow
HOW TO: H22 Auto Tensioner to H23 Manual Tensioner Conversion - courtesy of 98vtec
HOW TO: Install lowering springs/shocks with pictures - courtsey of Jlude
HOW TO: Replace Clutch and Slave Cylinders - courtesy of 98vtec
HOW TO: Remove Power Steering and Loop the lines - Courtesy of 98vtec
HOW TO: Polish headlights
HOW TO: Read Check Engine Codes
HOW TO: Suspension Install (GC/KYB AGX) - courtesy of hamadiscool
HOW TO: Wire JDM foglights with USDM switch - courtesy of edge2lyfe
HOW TO: Install 6.5" component speakers in a 5th gen - courtesy of Jlude
HOW TO: Tein Hood Dampers
Discussion/HOW To: 2.5" Collector mod for header applications
HOW TO: JDM Type-S Steering Wheel Swap - courtesy of bdoggprelude
HOW TO: Aftermarket seat install -Courtesy of Hprelude5r
HOW TO: LED Interior lighting- courtesy of pIOUs
HOW TO: LED Cluster Mod- courtesy of 00preludesh
HOW TO: Applying Lamin-x to JDM Fogs- courtesy of AtomKane
HOW TO: smoking your tail lights- courtesy of LUDEacris
HOW TO: cleaning your EGR ports-courtesy of Silver333
HOW TO: Install JDM Power folding mirrors- courtesy of SIRLude
HOW TO: Install dampers in your trunk - courtesy of AtomKane
HOW TO: Replace your fuel filter - couresy of Jlude
HOW TO: Under Dash LED lighting - courtesy of Jlude
HOW TO: DIY: H22A4 Valve Ajustment! - courtesy of Jlude
HOW TO: Clean your Vtec Solenoid! - courtesy of Ricedadee
HOW TO: Properly install PnP ballasts and wiring for HID Retrofits- courtesy of poet
HOW TO: Wheel Bearing Replacement - courtesy of Rocket3004
HOW TO: CRV 6 Disc Headunit swap - courtesy of BodggPrelude
HOW TO: WRITE UP: 5th gen SH ATTS to Base Conversion. - courtesy of aggreSHun
HOW TO: IACV Replacement
HOW TO: JDM Window Visors Install - coutesy of 97_Lude_VTEC
How TO: Remove Door Molding - courtesy of RomPirate
HOW TO: Brace your clutch pedal due to 5 speed swap - courtesy of doug684
HOW TO: Hidden aftermarket alarm install - courtesy of n0rmaL
HOW TO: Install Automatic Transmission Cooler - courtesy of RomPirate
HOW TO: Dual filament bulbs for front turn/park lights - courtesy of JBlude01
HOW TO: Fix that infamous bumper sag for good - courtesy of ethereal2pt2
HOW TO: Raise your stock prelude seats - courtesy of ludeyboy27
HOW TO: Yellow Capsule JDM fog light retrofit - courtesy of n0rmaL
HOW TO: 5TH GEN TIMING BELT change with manual tensioner conversion - courtesy of JLUDE
HOW TO: Fix Flappy door handle! - courtesy of RomPirate
HOW TO: VTEC Solenoid Gasket/Screen removal - Courtesy of Smitty2001
HOW TO: EDM rear foglight install 4th/5th gen - Courtesy of nOrmal
HOW TO: JDM Window Visors Install...(lots-O-pics) - Courtesy of 97 Lude VTec
HOW TO: 5TH GEN H22 cam plug seal replacement - Courtesy of 88si01sh
HOW TO: Install JDM cornering lamps and sidemarkers on a USDM bumper and fenders. - Courtesy of Shimee
HOW TO: Retrive CEL, ATTS, ABS, and 4WS Codes - Courtesy of Kronn 98SH
HOW TO: Footwell courtesy lights - Courtesy of Shimee
HOW TO: Fix that God damn temp. control cable. Forever! - Courtesy of Shimee
HOW TO: Stuff bigger, brighter bulbs into sidemarkers/parking lights - Courtesy of Shimee
HOW TO: Retrofit Replica Fog Switch "to" OEM JDM switch - Courtesy of Shimee
HOW TO: Give light to the glovebox gnomes. - Courtesy of Shimee
HOW TO: Project: Fog [complete; w/ write-up] - Courtesy of Shimee
HOW TO: Installing Morimoto mini projectors. - Courtesy of Shimee
HOW TO: Make your own trunk tray. - Courtesy of Shimee
HOW TO: Using CL sunroof switch in a 5th gen. - Courtesy of Shimee
HOW TO: where to get fog light mounting hardware - Courtesy of Shimee
HOW TO: Fix a broken headlight tab, the Shimee way. - Courtesy of Shimee
HOW TO: JDM in a bottle; DIY bulb tinting (failed LOLz) - Courtesy of Shimee
HOW TO: Installing an illuminated outlet from an Acura RL - Courtesy of Shimee
misc reviews
REVIEW: VIS Carbon Fiber Hood - courtesy of Boosted521
REVIEW: Falken Azeni RT-615 - courtesy of BlackSpeedLude
REVIEW: Seibon Carbon Fiber Hood - [/font]courtesy of irollow
REVIEW: BPi Flowstack - courtesy of 98vtec
REVIEW: Megan Test Pipe- courtesy of Silver333
REVIEW: Depo Aftermarket Headlamps - courtesy of prelude1897
REVIEW: Replica Fog Lights v2.0 - courtesy of Shimee
parts
5th Gen Parts Listing
exterior
Exterior Parts Listing - courtesy of 2qu1k4u
Last edited by Darren's 01 SH; 08-03-2010 at 11:20 PM. Reason: Added more info. Will be organizing soon.
charliec is offline
Closed Thread
Bookmarks
  • Submit Thread to Digg Digg
  • Ads By Google
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b21a1 car motivational posters convertible prelude dashboard paint edge2lyfe view profile floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22a4 specs h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen how to text your girlfriend hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews pcv valve symptoms power prelude prelude prelude convertible prelude forum prelude forums prelude power preludepower preludepower.com projector retrofit racing hart cp-035 rattle can paint job song suggester sweet things to say to your girlfriend in a text sweet things to say to your girlfriend over text sweet things to text your girlfriend things to text about things to text your girlfriend what to text your girlfriend www.preludepower.com
    Thread Tools
    Display Modes
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Forum Jump
    KickItBack = Cash Back
    Google
    vB.Sponsors
    PreludePower Forums
