Lowering springs/shocks install with pics on 5th Gen :o) - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 03-24-2003, 09:25 AM   #1
JLude
Idiotic Thread Locker!
JLude's Avatar
JLude is just really niceJLude is just really niceJLude is just really niceJLude is just really nice
Send a message via AIM to JLude
Thursday I did the Install of my new Tokico Shocks and sport springs in my garage. It took a total of 3 hours and I had all the tools I needed before beginning which helped speed the process.
Car: 2001 Honda Prelude 5 speed (non-SH)
Suspension set-up: Tokico Performance (blue) shocks / Tokico sport (red) springs (1.5" drop)
Tools required:
1.) Strut Spring Compressor - got mine from Autozone for $40 and I can return it if I decide not to keep it.
2.) Large ratchet with extensions and sockets in 10mm, 12mm, 14mm, 17mm, 19mm
3.) hydraulic floor jack (preferred) or another suitable jack
4.) at least two (2) jack stands to hold car once it is raised with jack.
5.) TORQUE WRENCH (a very good investment and required for safety)
Proceedures(pics at bottom of page):
1.) Break nuts free on front wheels
2.) Raise front end and place on jack stands
3.) remove front wheels
4.) Remove damper fork (wishbone), one bolt holding it to lower arm and one pinch bolt holding it to the stock shock assembly, once these bolts are removed the fork slides off the shock
5.) remove the 3 nuts holding the shock into the shock tower from the engine bay side
6.) work the shock assembly out of car (you may need to pry downward on the suspension upper arm to allow the shock to clear the lower arm and come out).
7.) use the spring compressor to release the tension on the springs and remove the end nuts on the assembly (you will need a 6mm? hex head and a 14mm closed end wrench to accomplish this). be sure the spring has no tension on the end cap before removing this nut!
8.) take apart the shock assembly and note the order of the bushings, washers.
9.) there are rubber bump stops on the shaft of the shock that you should shorten by an inch or so, these stops are what keep your car from bottoming out if you overcompress the springs on a large bump, etc.
10.) assemble the new spring on the correct shock and put the bump stop on the shaft and the dust cover (dust covers should also be shortened an inch). put the end cap back together on the new assembly (in the correct order) and snug the end nut as well as you can
11.) put the new assembly in the car and match up the lower fork grove on the shock with the orientation of the lower fork (you may need to rotate the spring slightly but since it was not under tension on my application I did this by hand)
12.) Once the shock is in tighten the 3 upper shock tower nuts by hand only. tighten the pinch bolt in the fork to 40 ft lbs torque (must use a torque wrench). tighten the lower through bolt (lower arm to fork bolt) to 47 ft lbs.
13.) lower the car and tighten the 3 upper shock nuts to 25 ft lbs
*Repeat proceedure for rear of car...(you will need to remove the bolt in the rear trailing arm and swing it down and back in order to remove and insert the shock assembly, otherwise it's about the same as the front except there is no fork, the shock attaches directly to the lower arm with a through bolt.
Pictures below with steps included (again)
Proceedures (with pics):
4.) Remove damper fork (wishbone), one bolt holding it to lower arm and one pinch bolt holding it to the stock shock assembly, once these bolts are removed the fork slides off the shock (damper fork attached to shock(blue) note that the driveaxle goes through the fork)
(front tower with nuts/shock removed)
7.) BEING VERY CAREFUL, use the spring compressor to release the tension on the springs and remove the end nuts on the assembly (you will need a 6mm? hex head and a 14mm closed end wrench to accomplish this). be sure the spring has no tension on the end cap before removing this nut! (spring compressor)
(removing end cap nut)
(front shock installed ready to lower car)
*Repeat procedure for rear of car...(you will need to remove the upper control arm, 2 nuts hold it from the trunk side, swing the arm down and around till the shock will clear, in order to remove and insert the shock assembly, otherwise it's about the same as the front except there is no fork, the shock attaches directly to the lower arm with a through bolt.
(rear shock tower bolt location)
(rear hub with rear trailing arm detached- DO NOT REMOVE THAT LOWER ARM, IT WILL EFFECT ALIGNMENT!)
(rear shock assembly installed)
(the finished product, springs should still settle for a few weeks, drop in this pic measures 1" from stock height)
Compliments of JLUDE, 2003...all you Lude owners are welcome...for those with other cars the procedure is similar but not exact. I found that my steering wheel is slightly off center after the lowering but the car tracks perfect straight line with hands off the wheels still...I plan to have the alignment checked soon which is recommended after lowering anyway. :yea:
Disclaimer: I take no responsibility for anyone attempting this install themselves. However it is a very simple procedure for those with decent skills in working with cars.
questions/comments encouraged
__________________
Building your custom HID Projector RETROFITS since 2005! PM FOR DETAILS.
Former 5th, 4th and 3rd gen Prelude owner. Current: 2004 Toyota Tundra V8 DC 4x4, '00 Civic LX beater, '06 Yamaha FZ6S, '07 Victory Kingpin - Still a Prelude enthusiast!
JLude is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-24-2003, 11:23 PM   #2
JapwaiianAngel01
Ludacious
JapwaiianAngel01 has disabled reputation
Send a message via AIM to JapwaiianAngel01
lookin awesome jesse!!
since u are my new modding partner in crime for suga, i'll know who to come to for my suspension hehe...
~ bri
__________________
A lil taste of heaven behind the wheel...
"The strikingly handsome, lightning-quick Honda Prelude. You may fall in love." - Honda.com
JapwaiianAngel01 is offline   Reply With Quote Quick reply to this message
Old 08-22-2006, 11:14 AM   #3
supdood123
Getting Comfortable
supdood123 is on a distinguished road
Just wanted to post that this is a good write-up, JLude.
If I could add anything, it would be about the notching on the strut assembly. These have to line up so that the wishbone has the proper distance and seating. One of my struts wasn't lined up properly, and the old upper strut bushing wasn't receptive to rotating into alignment. A few grinds later, I removed the notch on one side.
I'd advise to anybody to consider replacing the upper mounts and maybe even the factory bottoming bushings. The new struts won't include the bottom out bushings.
Also, one trick to getting the whole assembly in/out without having to significantly move/hold the control arms is to slot the spring against the upper arm and unscrew/screw it out. Sounds weird, but it worked like a charm. You basically force the spring to get caught on the upper arm within one of the spring gaps, and unscrew it.
supdood123 is offline   Reply With Quote Quick reply to this message
Old 08-22-2006, 11:54 AM   #4
prelude1897
prelude1897's Avatar
prelude1897 is a jewel in the roughprelude1897 is a jewel in the roughprelude1897 is a jewel in the rough
Send a message via AIM to prelude1897
good write-up and pics
__________________
97 Prelude-wrecked
00 Prelude-daily driver
99 Prelude-RHD Prelude
98 Prelude-Parts Car-SOLD
97 Prelude-RHD project#2
99 Prelude-Parts car-SOLD
01 Prelude-Parts car-SOLD
94 Prelude-VTEC status-Traded
98 Prelude-traded for 94 prelude
97 Prelude-Parts car-SOLD
Retrofit Service PM me
prelude1897 is offline   Reply With Quote Quick reply to this message
Old 08-22-2006, 11:53 PM   #5
Sway_NV
Lude Boss
Sway_NV's Avatar
Sway_NV is on a distinguished road
Send a message via MSN to Sway_NV
^^^ Ditto, looks real good. Kudos to you!
__________________
Bye Bye Lude
Now Driving a G37S 6MT Coupe
Friggen Smart People:
98vtec (2.2L),
Prelude 1897, JLude, ludetech,
Honda4Life,
Cruiserdude, irolllow, poet, Spoolin BB1, shinjimae
If prelude models were being sold, I would buy like 12 and have toy prelude meets on my desk. I would also buy a civic for all the toy preludes to laugh at
Sway_NV is offline   Reply With Quote Quick reply to this message
Old 08-23-2006, 01:25 AM   #6
Zero1Lude
Lude Dude
Zero1Lude's Avatar
Zero1Lude is on a distinguished road
Wow this is a great thread for newbies like me... More power JLude!
How long does this take if you were to get it done in a shop? and around how much?
__________________
2001 Honda Prelude
Zero1Lude is offline   Reply With Quote Quick reply to this message
Old 08-23-2006, 01:52 AM   #7
CruZin89LuDe
Prelude Aficionado
CruZin89LuDe's Avatar
CruZin89LuDe has disabled reputation
Send a message via AIM to CruZin89LuDe
personally, i'd say I could do it in about an hour more than it would take a shop with a lift and air tools. It's way easier once you've done it a few times.
your first time doin it i'd allow an entire day, just because you don't know exactly what you're doin yet.
a shop would charge maybe 2 or 3 hundred for this, i'm sure you can find shops that charge more than that.
__________________
So I left the honda world behind. My legacy GT wagon is my new baby, but I'll always love my ludes.
This is the best forum on the internet, even if half you guys are A-holes
CruZin89LuDe is offline   Reply With Quote Quick reply to this message
Old 08-23-2006, 07:06 AM   #8
Fugative4385
I miss her...
Fugative4385's Avatar
Fugative4385 is on a distinguished road
these guys always motivate me to get off my bootay and do it myself!
good job and thanks for the post!
Fugative4385 is offline   Reply With Quote Quick reply to this message
Old 08-23-2006, 10:28 AM   #9
HS2G
Lude Dude
HS2G is on a distinguished road
i'll be honest, drop doesn't look good according to that picture. But thats my opinion. Looks too similr to stock even if it still needs to settle 1/2 inch more. i'd say a 2inch + drop would have been worth the $$ instead if getting a 1-1 1/2 inch drop for the same amount.
HS2G is offline   Reply With Quote Quick reply to this message
Old 08-23-2006, 04:16 PM   #10
supdood123
Getting Comfortable
A shop will want 2+ hours of labor to do the swap. They have these spring compressors that are air powered which will easily drop a half hour of just fooling with the compress and uncompress process.
Plan a day to DIY, be happy if you finish in half. Once I figured out how to do the first side (a few hours), the second took about an hour.
I noticed a lot of people are doing at least 1" drops as standard practice. Do you need any sort of camber/caster kit for that application?
Old 08-24-2006, 10:17 PM   #11
stupafly22
SuperCharged & SuperPoor
stupafly22's Avatar
stupafly22 is on a distinguished road
Send a message via AIM to stupafly22
you notice more of the rear dropping lower than the front by chance?
__________________
Black '99 SH Supercharged <---Repaired
Blue(soon Sunset Red Metallic Pearl) '01 - Almost Done!
Black '98 Blazer ZR2 - SOLD'
Black '98 Jeep Grand Cherokee V8
THOUROUGHLY ENJOYING MY GF MOD
JR Supercharger*Stock Internals*JR Management System
AEM Intake*A'pexi N1 Exhaust*ARP Head Studs*MSD Distributor Cap*Autometer Boost and A/F Gauges*Jegs Fuel Pressure Gauge
Vacating the '99 for the '01
Spring '08
stupafly22 is offline   Reply With Quote Quick reply to this message
Old 08-25-2006, 07:31 AM   #12
Hprelude5R
Hprelude5R's Avatar
Hprelude5R will become famous soon enoughHprelude5R will become famous soon enough
Bloody hell.
How is it that this thread can be so old, yet only now is getting noticed??
Great write up...This needs to be in the resource thread.
Hprelude5R is offline   Reply With Quote Quick reply to this message
Old 07-23-2008, 11:13 AM   #13
YellaLude
UK VTi Motegi bAby!
YellaLude's Avatar
YellaLude will become famous soon enough
Send a message via AIM to YellaLude Send a message via MSN to YellaLude
Prelude of the Month
Any chance of these pictures working again on this How To? I need to check something with regards to installing the rear shock.
__________________
'99 Prelude 2.2 BB8 VTi 4WS Motegi H22A8...SOLD
YellaLude is offline   Reply With Quote Quick reply to this message
Old 07-23-2008, 02:07 PM   #14
viper_boy403
Vrooom PSHHHH
viper_boy403's Avatar
viper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to behold
Send a message via AIM to viper_boy403
Hamadiscool has a similar write up, just search for threads created by him. I'll see if I can dig it up
Here it is
http://preludepower.com/forums/showthread.php?t=270244
__________________
- Competition Clutch - MFactory - Prosport - Skunk2 - Neptune - Innovate - Seibon - H&R- KYB - Tial - Injector Dynamics -
- Energy Suspension - Vibrant - Aeromotive - Synchrotech - Quaife - GE - Hawk - Innovative Mounts - CP - Eagle -
BOOSTED
1997 San Marino red base
-Andrew-
Fuck bitches... acquire boost.
viper_boy403 is offline   Reply With Quote Quick reply to this message
Old 10-31-2008, 05:29 PM   #15
randomman84
True Luder
randomman84's Avatar
randomman84 is on a distinguished road
pics are dead!
__________________
Love my Lude..
randomman84 is offline   Reply With Quote Quick reply to this message
Old 10-31-2008, 06:14 PM   #16
NegativeXero
Elite Member
NegativeXero's Avatar
NegativeXero is just really niceNegativeXero is just really niceNegativeXero is just really niceNegativeXero is just really nice
Originally Posted by randomman84 View Post
pics are dead!
Well duh, they are about 5 years old. Just giving you a hard time.
__________________
1972 Chevrolet Camaro - 350/TH350, Viper Racing yellow, lots of err..custom parts.
2001 Mazda Miata - Little car...little stick
NegativeXero is offline   Reply With Quote Quick reply to this message
Old 11-06-2008, 04:57 PM   #17
randomman84
True Luder
can anyone reup the pics for this?
__________________
Love my Lude..
Old 11-06-2008, 05:19 PM   #18
ffxbb6
Prelude Aficionado
ffxbb6's Avatar
ffxbb6 has a spectacular aura aboutffxbb6 has a spectacular aura about
Send a message via AIM to ffxbb6
if u need help
PM me i can prob help u
__________________
98' RHD BB6 Jdm H23a, M2B4 lsd
06' Evo IX MR SE
Japanese Engine Import : Need Engines? Trans? Rare Parts? Shoot me a Email
ffxbb6 is offline   Reply With Quote Quick reply to this message
Old 11-07-2008, 07:40 AM   #19
JLude
JLude's Avatar
You A-holes are going to make me put these pics back up aren't you? 5 1/2 years later!
__________________
Old 11-07-2008, 08:12 AM   #20
daluder
Lude Boss
daluder's Avatar
daluder is on a distinguished road
__________________
2008 World Series Champions Philadelphia Phillies
holy sh*t..holy sh*t..
daluder is offline   Reply With Quote Quick reply to this message
Old 11-07-2008, 10:30 AM   #21
randomman84
True Luder
Thank you!!!!!!!
__________________
Love my Lude..
Old 11-07-2008, 02:12 PM   #22
timelessr1
Lude Dude
timelessr1's Avatar
timelessr1 is on a distinguished road
Is that sub box made out of particle wood?
timelessr1 is offline   Reply With Quote Quick reply to this message
Old 11-07-2008, 02:18 PM   #23
JLude
JLude's Avatar
Yup, 3/4", it's stronger than plywood and that was before I carpet covered it but I haven't had a sub in my car since 2005. Amp powered components and 6X9's in the deck are perfect and save weight. Believe it or not that sub box had excellent resonance. Deep, full bass with no distortion at all frequencies it could handle. Girls used to sit in the back just to get a full body massage.
__________________
Old 11-08-2008, 02:05 AM   #24
Darren's 01 SH
I am Prelude
Darren's 01 SH's Avatar
Darren's 01 SH is a name known to allDarren's 01 SH is a name known to allDarren's 01 SH is a name known to allDarren's 01 SH is a name known to allDarren's 01 SH is a name known to allDarren's 01 SH is a name known to all
Good writeup, Jesse. After seeing exactly how to do it on a lude I might do this myself now.
Darren's 01 SH is offline   Reply With Quote Quick reply to this message
Old 04-02-2010, 01:33 AM   #25
SeigiSama
True Luder
SeigiSama's Avatar
SeigiSama is on a distinguished road
To resurrect an old thread:
Thanks for the write up. I didn't think it looked hard, and from you're write up now I know it isn't.
These are the exact same springs and struts I have, but haven't installed yet. How is the ride? Too stiff too rattly? How well did they hold up over time?
Oh and Just to nit-pick the tool you called a: "6mm? hex head" a is an "allen wrench an Allen key or and L-Key" the bolt is an "Allen bolt" there are a few different types "Flat allen (shaped like a cone usually conter sunk to sit flush), Allen cap (rounded "spherical shape"), allen head (cylindrical shaped), and allen shoulder bolt (flat cylindrical with a machined "shoulder" and short threads)." "Hex Head" is any normal 6 sided Bolt Head. Hence "hex (six) head." There's also 4, 8 and 12 sided bolt heads. 4 Sides are common 8 and 12 are specialty bolts. The germans like to use them on their machinery.
Just didn't want anyone running out and buying a wrench for a "6mm hex head," and ending up with a regular open/closed ended wrench in 6mm instead of a 6mm allen wrench.
__________________
2000 Honda prelude BASE, Full exhaust Sus-Teq F&R Swaybars, Polly bushings, custom end-links, Tokiko Shocks and Springs. 17" Enkei EVO5 (old style) 215 40zr17 S-Drives (slow and steady)
2007 Mazdaspeed 6: 19 PSI 305 AWHP @ 5500 333AWTQ @3200. Drag DR21's 18" 225 40zr18 Nitto Invos (ego murderer)
SeigiSama is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
mcw53
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
