3rd gen wiring ! - Honda Prelude Forum : Honda Prelude Forums
Old 11-07-2003, 01:21 AM   #1
orgasm_donor
orgasm_donor has disabled reputation
3rd gen wiring !
Did a little research on wire identifications. If you are installing a deck and your wires have been cut or if you want to do an alarm, this list of wiring colors and polarities should help. It is for an 88-91. The list starts with function - color - location - polarity
12 volts - white - Ignition harness - pos
Ignition - black/yellow - Ignition harness - pos
Accessory - Yellow - Ignition harness - +
Starter - black/white - Ignition harness - pos
Tach - blue - at coil in eng. - AC
Lock - green/white - drivers kickpanel - neg
Unlock - green/red - drivers kickpanel - neg
Doorpin - black/white - plug at fusebox - neg
Trunk pin - green/black - plug at fusebox - neg
Brakeswitch - green/white - switch above brake pedal - pos
Parklights - red/black - light switch harness - pos
Horn - blue/red - steering column harness - neg
Driver window up - red/blue - main window switch - rev pol
Driver window down - red/yellow - main window switch - rev pol
Pass window up - blue/green - main window switch - rev pol
Pass window down - blue/yellow - main window switch - rev pol
Headlights - blue/red - light switch harness - neg
Reverse lights - Green/black - large harness in drivers kick - pos
Dimmer - red/green OR red - any illuminated switch
VSS wire - Orange - cruise module on right of column
Key Sense - blue/white - Ign harness - neg
Here are the audio wires:
Battery(+) - white/blue
Accessory(+) - white/green OR Yellow/red
Ground(-) - Black
Illumination(+) - red/black OR blue/white
Power antenna(+) - yellow/white
LF speaker(+) - blue/green
LF speaker(-) - gray/black
RF speaker(+) - red/green
RF speaker(-) - brown/black
LR speaker(+) - blue/yellow
LR speaker(-) - gray/white
RR speaker(+) - red/yellow
RR speaker(-) - brown/white
Hope this all helps !!!
Mike
2003 350Z Touring - 19" Volk TE-37's - Cusco - Tein flex - JWT Popcharger - Magnadyne spacer - Stillen Sways - RS-R Exmag exhaust - full system
2005 Acura TSX - 19" Tenzo R TENSPECS - Tein S-tecs - HPS CAI - Greddy exhaust - full system
orgasm_donor is offline   Reply With Quote Quick reply to this message
Old 11-07-2003, 07:03 AM   #2
LewdLude
Lude Boss
LewdLude's Avatar
LewdLude is on a distinguished road
that helps alot, thanx! whats VSS though? and if my lude didnt come with electric locks will it still have the wires?
"Drive fast and don't take any of this stuff seriously!" - Some kid from Space Camp
LewdLude is offline   Reply With Quote Quick reply to this message
Old 11-07-2003, 03:48 PM   #3
orgasm_donor
VSS = Vehicle speed sensor.
Power lock wires are generally not in vehicles which came without that option. If you are adding power locks, best bet is to go straight to the alarm brain (via relay).
Mike
Old 11-07-2003, 06:23 PM   #4
tricken
Lude Boss
tricken's Avatar
tricken is an unknown quantity at this point
Send a message via AIM to tricken
thanks man that will help a ton need to pull the old alarm crap out some one hooked it up wrong
95 accord wagon sold
71 vw squareback fi under the knife
........ coming soon
tricken is offline   Reply With Quote Quick reply to this message
Old 11-07-2003, 06:36 PM   #5
LudaPower
LudaPower is a jewel in the roughLudaPower is a jewel in the roughLudaPower is a jewel in the rough
OMG! Thnx a lot! Now I might just figure out why my battery is dying all the time! thnx moochos!
you wouldnt have info for the signals would you? I got major probs with those also
LudaPower is offline   Reply With Quote Quick reply to this message
Old 11-09-2003, 12:41 AM   #6
orgasm_donor
Nah, sorry mate.
Mike
Old 11-09-2003, 01:12 AM   #7
mouchyn
Prelude Aficionado
mouchyn is on a distinguished road
Send a message via ICQ to mouchyn Send a message via AIM to mouchyn Send a message via Yahoo to mouchyn
what problems are you having with them?
~Chris
Just call me the Thread Locker.
mouchyn is offline   Reply With Quote Quick reply to this message
Old 11-09-2003, 08:53 PM   #8
Slipslap
Unactive
Slipslap is on a distinguished road
Where were you a month ago when i put my alarm in ? I never could find the door pin wires for my alarm. And I don't feel like taking that crap out and doing it again. I might do it when I buy my door lock actuators, so I can have remote door locks. They cheap on ebay.
looking for a 3rd gen engine
READ this about engine ADDITIVES
Turbo manifolds for sale
Your car must be fast, cause you were flying when I passed you!
Slipslap is offline   Reply With Quote Quick reply to this message
Old 11-10-2003, 12:34 AM   #9
mouchyn
Prelude Aficionado
had you posted your problems here, we could have helped you. i would have pointed you over to www.the12volt.com where most of that info is listed...
~Chris
Old 11-10-2003, 08:15 AM   #10
Slipslap
Unactive
I did, liquid51 helped me and found most of the wires for me. I never could find that dam door pin actuator wire though. So thats not hooked up to my alarm still.
Old 11-10-2003, 08:29 AM   #11
mouchyn
Prelude Aficionado
i tapped a single wire that feed into the cluster for the "door open" warning light. That was the one listed at the12volt.com and it works like a charm.
~Chris
Old 11-10-2003, 10:53 AM   #12
Slipslap
Unactive
I might have to try that when I'm back in there. I'm not takeing that crap out just to do that. I'm gonna make it worth my time when I got a few things to do.
Old 09-20-2004, 12:16 PM   #13
heyfrench
Quasi-AWOL
heyfrench's Avatar
heyfrench is on a distinguished road
Here's a How-to for installing a new deck into the 88-91s, with pictures and audio wires identified as well:
http://www.installdr.com/InstallDocs...PDF/466045.pdf
He's the baddest mofo in the world who just so happens to not be french.
FOR SALE:
heyfrench is offline   Reply With Quote Quick reply to this message
Old 06-01-2005, 10:50 AM   #14
LewdLude
Lude Boss
LewdLude's Avatar
Okay, where exactly is the VSS wire? Are you talking about the plug that plugs into the gauge cluster on the right side? If so, there is no orange wire.
Old 03-30-2008, 08:08 PM   #15
black91crx
black91crx is on a distinguished road
bump from the dead for an answer
black91crx is offline   Reply With Quote Quick reply to this message
Old 03-30-2008, 08:58 PM   #16
88si01sh
Lude Cray
88si01sh's Avatar
88si01sh will become famous soon enough
88-89 didnt use electronic vss, they used the 'ol cable drive, only 90-91 were electronic. Holy crap this thread is old.
88si01sh is offline   Reply With Quote Quick reply to this message
Old 03-30-2008, 09:00 PM   #17
black91crx
yeah, mines a 91. just wondering where i can find the wire under the dash so I can test it for a signal.
Old 03-30-2008, 09:10 PM   #18
cudaboy
cudaboy's Avatar
cudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internetcudaboy is the King of the Internet
Send a message via Yahoo to cudaboy
use the shop manual and stephen guessman's wire locator write up both located in the f.a.q. on 3rd gen forum.
CUDABOY'S STRUT TOWER BAR GROUP BUY: I HAVE 1 FRONT OF BLACK ON BLACK W/SILVER BAR FRONT $150/SH +3 SETS F/R U CHOOSE COLOR MINI G.B. $265 SH.
'91 Si 4ws 5spd(black) "Black Betty"
'70 'Cuda 340 C.I.D. Alpine White, Black Vynil Top, Leather Interior, Rim Blow, Overhead Consolette. Factory Posi 3.55:1, 15" ralleyes, --Fully Loaded and Extremely Rare!
cudaboy is offline   Reply With Quote Quick reply to this message
Old 03-30-2008, 09:14 PM   #19
cudaboy
cudaboy's Avatar
VSS wire - Orange - cruise module on right of column --Not sure what mike meant by that. maybe he is referring to the buttons on dash. Anyway the actual box that is the brain for cruise control and normally called the control module is located behind drivers kick panel and is the big silver box mounted on relay bracket.
Old 07-06-2011, 05:14 AM   #20
Ludercrs
Prelude Aficionado
Ludercrs's Avatar
Ludercrs will become famous soon enough
just an update for the FAQ but in the Audio section for the battery there's a second option:
Battery(+) - white/blue OR white/yellow
i didn't have white/blue and took me a while to find out it was the white/yellow
2011 Honda CR-Z - DD
1991 Honda Prelude SE - LEATHER SEATS BABY - H22 - 180whp - 160tq
Ludercrs is offline   Reply With Quote Quick reply to this message
Old 08-30-2016, 07:22 PM   #21
dan macmillan
dan macmillan is on a distinguished road
Ground(-) - Black
Mike
Thanks
dan macmillan is offline   Reply With Quote Quick reply to this message
