quick question
when I shift from 1st to 2nd gear
my lude begins to shake a bit
sometimes even from 3rd to 4th..
my friend says I need motor mounts
would you recommend I get these
so that the shaking will stop??
not at all, when people drill the hole bigger because for some reason
1/ they took out the whole motor just to change motor mounts
2/ they tighten up the mounts way be for that install all of them
so solution is you need to keep all mounts lose so you will have room to mess around
did you use one jack under the engine so you can use that jack to move the engine around? my friend install all 4 of the mounts from the top, he never had to get under the car
they do, the front does not come with the set, you have to buy that indiviually, and the 4th one will make your car feel completelly different, trust me on this cause i have all 4 on mine
I just ordered these for my 97 lude with the extreme bushings(95a)... I know they are almost solid... I hope it's not too crazy to drive on the street. I'll let you know when they are installed what I think of the extreme bushings.
I'm scared to put my 75a's in. Honestly if 65a's were an option a year ago i would have bought those. 75a's with no balance shaft may be a little to much vibration for me. I'll post up in a month once the car is finished up and running.
okay ... not going to lie tons of vibration with these mounts. i have 3 on my turbo lude... i do not think the front is needed. huge difference in performance ... motor barely moves. i have my balancer shafts removed too... so vibration shakes my review. overall worth every penny. on my all motor 5th gen i will be using these mounts also.
Related Threads
Honda Prelude Forum
2.9M posts
61K members
Since 2002
