The Official Oil Leak Guide - Page 7 - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 07-12-2015, 10:06 PM   #151
Wing8806
Faptastic
Curveball Champion, Alien Clones Champion
Wing8806's Avatar
Wing8806 is a name known to allWing8806 is a name known to allWing8806 is a name known to allWing8806 is a name known to allWing8806 is a name known to allWing8806 is a name known to all
Get the car on stands and check for leaks
__________________
2001 Prelude - Project
2008 Mugen Si - Daily
Do not trust Kane666 aka Jason Myers.
Wing8806 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-13-2015, 10:25 AM   #152
no0ne
Newbie
no0ne is on a distinguished road
Theres just a couple of drops of oil underneath. If leaking would be the main reason of dissapearing oil, everything down there would be messy and black.
no0ne is offline   Reply With Quote Quick reply to this message
Old 07-13-2015, 11:30 AM   #153
Wing8806
Faptastic
Wing8806's Avatar
If its burning off before hitting the ground or building up somewhere...it would be hard to tell
Trace the drops. Clean whats there.
Do a compression test if you feel it may be the rings
__________________
Old 12-15-2015, 08:07 AM   #154
shibby2554
Newbie
shibby2554 is on a distinguished road
Sorry to bump a really old thread, but I just solved my leak issue and wanted to share.
Someone mentioned this before but might be worth adding the VTEC solenoid base gasket to the list. That ended up being my issue. 36172-P08-015
I was leaking almost 5 quarts between oil changes because of that. It finally cracked and leaked a quart in 10-15 minutes.
shibby2554 is offline   Reply With Quote Quick reply to this message
Old 12-19-2015, 02:22 PM   #155
bmv2000
Lude Dude
bmv2000 is on a distinguished road
Great helpful article. And always liked those E-36s.
bmv2000 is offline   Reply With Quote Quick reply to this message
Old 01-15-2016, 09:39 AM   #156
starbai
True Luder
starbai's Avatar
starbai is on a distinguished road
Send a message via AIM to starbai Send a message via MSN to starbai
Originally Posted by 00-SH View Post
I gotta say this is one of the best write-ups I've ever seen. I used this today to change the seals in my engine. I have an SH, and the oil pressure switch was leaking. This little sucker is located underneath the intake, above the ATTS unit, and far enough past the oil filter housing as to make it impossible to reach without taking off the ATTS. Unfortunately, I couldn't take off the ATTS because the driver's side axle refused to come out, and it blocks one of the bolts that holds the ATTS to the block, so I pulled the engine. Bit drastic, but effective. And it made it very easy to change the seals. Piece of advice: When taking off the crank gear, there is a small retainer under it with two 10mm bolts holding it to the block. I didn't see this and managed to snap the edge off the gear backing plate. Serious crapola. But all that to say that I wouldn't have been able to do this without MommysLittleMonster and his amazing leak guide. Thank you!
Is it possible to buy just the oil pressure switch seal? or do you need to buy the entire switch? My engine is currently out an I'm replacing litereally every seal I can (need it or not) beacuse I'm hoping i dont have to do this for another 100k. Since this one is so hard to get to once the motor is back in the car I'd like to take care of it. Any advice? I'm having a tough time finding a part number for just the seal.
__________________
starbai is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
