OFFICIAL: Retrofit Discussion, Question, and Info Thread - Page 3 - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 07-26-2010, 05:24 PM   #51
prelude1897
prelude1897's Avatar
prelude1897 is a jewel in the roughprelude1897 is a jewel in the roughprelude1897 is a jewel in the rough
Send a message via AIM to prelude1897
I always use self taping screws and add JB weld on them so that they don't back out
__________________
97 Prelude-wrecked
00 Prelude-daily driver
99 Prelude-RHD Prelude
98 Prelude-Parts Car-SOLD
97 Prelude-RHD project#2
99 Prelude-Parts car-SOLD
01 Prelude-Parts car-SOLD
94 Prelude-VTEC status-Traded
98 Prelude-traded for 94 prelude
97 Prelude-Parts car-SOLD
Retrofit Service PM me
prelude1897 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-26-2010, 05:25 PM   #52
Honda-R
Lude Boss
Honda-R's Avatar
Honda-R will become famous soon enough
so how do you aim the lights?
__________________
My Ride: 01 EBP Lude
BB Squad #9 v.2
Honda-R is offline   Reply With Quote Quick reply to this message
Old 07-26-2010, 08:26 PM   #53
JLude
Idiotic Thread Locker!
JLude's Avatar
JLude is just really niceJLude is just really niceJLude is just really niceJLude is just really nice
Send a message via AIM to JLude
Self tapping screws to hold the projector to the reflectors? No bolts with washers and nuts on the backside? I would not trust self tapping screws to hold well enough into the friable reflector bowl material which just splinters when you screw into it. I'm not saying your method isn't solid I'm just not sure how self tapping screws can even be screwed into the reflectors which are very dense and friable material.
__________________
Building your custom HID Projector RETROFITS since 2005! PM FOR DETAILS.
Former 5th, 4th and 3rd gen Prelude owner. Current: 2004 Toyota Tundra V8 DC 4x4, '00 Civic LX beater, '06 Yamaha FZ6S, '07 Victory Kingpin - Still a Prelude enthusiast!
JLude is offline   Reply With Quote Quick reply to this message
Old 07-26-2010, 10:16 PM   #54
prelude1897
That's where the JB weld comes in handy. You add the JB weld on the backside of the screws so that they don't come loose from all the vibration. I wouldn't suggest it if it hasn't been working for me with all the lights I've dealt with
__________________
97 Prelude-wrecked
Old 07-28-2010, 01:54 AM   #55
Honda-R
Lude Boss
Honda-R's Avatar
What direction should i mount my e46 shrouds on my FXR's...it seems that is i put the round part on the top where the solenoid is on the bottom it might not cover the solenoid completely....but if i put the round side on the bottom where the solenoid is and the flat part on to it dosen't cover the top part all the way.
__________________
BB Squad #9 v.2
Old 07-28-2010, 11:39 AM   #56
JLude
JLude's Avatar
Different people do this different ways. Personally I have found it works much better if you put the flat part on the bottom. You'll have to trim some of the flat part away so it will seat down deep enough over the solenoid. Also you will have to cut some of the upper part of the headlight reflector away so the bezel can seat down all the way on the top. Then I just cut the "round" top part of it off straight and level with the top of the reflector, then cut a piece of thin aluminum flashing to cover the gap in the top and use high temp silicone to glue it to the bezel and also to the reflector, this works to cover the gap and also makes your bezel MUCH stronger attachment so it will never loosen up on you.
You can see how I did it for the most part in these pictures:
Notice that the flat part is on the bottom, you can see a tiny bit of the FX solenoid but once in the headlights you can't see it.
In this last picture see how I dremel cut the round top part of the E46 bezel to follow the exact curvature of the headlight reflector on top.
__________________
Old 07-28-2010, 11:59 AM   #57
Honda-R
Lude Boss
Honda-R's Avatar
Hmmm ok. so i have to cut some of the headlight? I was afraid i would have to do that....and this aluminum flashing is just a piece of aluminum like at lowes or something?
__________________
BB Squad #9 v.2
Old 07-28-2010, 12:06 PM   #58
ludepowerh22a
Getting Comfortable
ludepowerh22a's Avatar
ludepowerh22a is on a distinguished road
for testing project postion in reflector, how did you connect 12v and did you connect direct to light with DS2 bulb adapters?
ludepowerh22a is offline   Reply With Quote Quick reply to this message
Old 07-28-2010, 12:09 PM   #59
Shimee
Abscissa & Ordinate
Shimee's Avatar
Shimee has much to be proud ofShimee has much to be proud ofShimee has much to be proud ofShimee has much to be proud ofShimee has much to be proud ofShimee has much to be proud ofShimee has much to be proud ofShimee has much to be proud of
You need to trim the shroud that you mount to the projector so it doesnt hit the headlight lens. The flashing is just some thin sheet metal. When you cut the shroud you'll be exposing the projector from the top, so you use the flashing to cover the hole.
You have to use a ballast else you can blow your bulb or damage the battery.
__________________
Click to see my >>
> replica foglights, footwell lights, temperature cable fix, EDM rear fogs, Morimoto projectors, replica fogs, and more!
Shimee is offline   Reply With Quote Quick reply to this message
Old 07-28-2010, 12:30 PM   #60
JLude
JLude's Avatar
Shimee pretty much hit the nail on the head. The flashing I use is aluminum and is thin enough to be cut with scissors I found it at Lowes or Home Depot.
__________________
Old 07-28-2010, 05:51 PM   #61
ludepowerh22a
Getting Comfortable
i guessing going to need to cut pretty big hole in reflector to fit FX-R.
Old 07-28-2010, 05:56 PM   #62
prelude1897
yea, it's a pretty decent size
__________________
97 Prelude-wrecked
Old 07-28-2010, 05:59 PM   #63
ludepowerh22a
Getting Comfortable
how far up on reflector did you have cut?
Old 07-28-2010, 06:04 PM   #64
prelude1897
I don't ever take measurements, but you cut up the reflector bowl enough to fit the projector through. I just use my air die and cutting wheel and start cutting. Using a dremel is the same thing
__________________
97 Prelude-wrecked
Old 07-28-2010, 06:18 PM   #65
ludepowerh22a
Getting Comfortable
wow this projector is tall, did you cut into high beam bowl (just alittle)?
Old 07-28-2010, 06:25 PM   #66
prelude1897
Just a little bit, but not to where you can't still put your stock bulb in
__________________
97 Prelude-wrecked
Old 07-28-2010, 09:56 PM   #67
Honda-R
Lude Boss
Honda-R's Avatar
any cutting on the projector?
__________________
BB Squad #9 v.2
Old 07-30-2010, 10:48 AM   #68
NightHawkLude
Lude Addict
NightHawkLude's Avatar
NightHawkLude is on a distinguished road
how long bolts do you use?
NightHawkLude is offline   Reply With Quote Quick reply to this message
Old 07-30-2010, 04:36 PM   #69
Sup3r D
Lude Dude
Sup3r D is on a distinguished road
Some cars you can go based off the reflector bowl, but other cars, you'll need to make a platform, cause when the housings might be sitting flat, the reflector bowls are a little angled such as civics and newer accords
Use 2-3 inch long bolts and cut them off after you've locked them in.
__________________
Goodbye WDP Prelude... Hello.. Milano Red Prelude!!
Detailing a Milano Red Prelude.. VIEW HERE!!
Sup3r D is offline   Reply With Quote Quick reply to this message
Old 07-30-2010, 11:07 PM   #70
catacon
Ludimus Catacus
catacon's Avatar
catacon is a jewel in the roughcatacon is a jewel in the roughcatacon is a jewel in the roughcatacon is a jewel in the rough
What's the best way to clean up shrouds and reflector bowls?
GO!
catacon is offline   Reply With Quote Quick reply to this message
Old 07-30-2010, 11:11 PM   #71
prelude1897
I just use my shirt. You don't really want to use any chemicals, cause you risk cleaning the chrome paint off on the reflector bowls
__________________
97 Prelude-wrecked
Old 07-30-2010, 11:12 PM   #72
catacon
Ludimus Catacus
catacon's Avatar
Nice. I like it. What about the lenses?
Old 07-30-2010, 11:13 PM   #73
prelude1897
same way
__________________
97 Prelude-wrecked
Old 07-31-2010, 12:20 AM   #74
Sup3r D
Lude Dude
+1, goo gone is not safe for the reflectors
__________________
Old 07-31-2010, 01:22 AM   #75
Shimee
Abscissa & Ordinate
Shimee's Avatar
Use a nice, fluffy microfiber towel if you want the easiest method of removing any fingerprints or crap from the reflector bowl. But be careful because even heavy scrubbing will start rubbing the finish away.
Most headlights are made on the cheap and are not actually chrome plated. For one, the material they use for the reflector cannot be chrome plated because it cannot be electrostatically charged. Instead they use an aluminum vapor deposition method for the finish. This electrochemically bonds a thin layer of aluminum with the reflector bowl and isn't a mechanical finish like chrome. So even alcohol can reduce the finish and strip it away.
__________________
Click to see my >>
Sponsored Links
Advertisement
Reply
Bookmarks
Tags
hid, projector, projectors, retrofit, retrofits, retrofitting, shroud, shrouds
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
