Untangling the spaghetti and removing unnecessaries... - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 06-01-2008, 12:15 AM   #1
fullthrottle_man
Lude Boss
fullthrottle_man's Avatar
fullthrottle_man is on a distinguished road
Ok gang. I decided to start a thread about what's needed, not needed, what can get pitched and what must stay as far as the vacuum spaghetti goes under the hood. The guinea pig is my 87 DX. All you Si guys, I'm not sure how much of this will apply to you. But I'm sure it'll at least help. Anyways, I'll update this as often as possible to keep you guys informed of my progress with the spaghetti removal.....
And remember, I'm not responsible for anyone screwin up their car by following what I did. And smog-test takers, you guys will probably just have to wonder how much this might help your car instead of actually doing it... LOL
All vacuum line numbers I refer to are how they are numbered from the factory (or at least as far as I know...all my line numbers correspond with the manuals I've seen anyways...).
First thing I did was ditch the EGR. Emissions crap. Unplug lines #4 and #5 coming from the black box of death (right side of engine bay on firewall) where they meet the metal lines on the engine. Plug off the metal lines. You can also open up the black box and remove the vacuum switches/solenoids that those lines went to, or just cut off the rubber lines where they go into the box. Then you can leave the EGR valve there if you want, or you can make a block-off plate to tidy it up a bit. Also you can remove the EGR tube going to (coming from) the exhaust manifold to the intake. A plug will have to be made for the exhaust manifold, and if you do the block-off plate you may need a plug made for the intake side as well.
6/1/08 -- I did some removal of goods in the black box of death. If you crack open the box you will find a myriad of vacuum switches, check valves, an air filter, etc. etc. At the bottom inside the box is a large aluminum double valve. That's for the EGR and can be taken out of the box and tossed. At this point you can also get rid of the vacuum switches and air filter that are connected to the aluminum valve assembly. Two of the vacuum switches have a single wire going to them. Chop the wire on each of the switches and yank them out. Then you can reassemble the box and reinstall.
Stuff from the black box...
Now, see the black box next to the upper timing cover? And the big hose going from it to the black box sitting on the intake? Get rid of all of it. Both black boxes and the associated large tubes. I kept the tube that runs from the box at the timing cover to the air cleaner assembly and plugged it off. The smaller lines just trim back and plug however you see fit that appeals to your eyes. The aluminum piece connected to the second black box (the one on the intake manifold) I haven't taken off yet so I don't know if there's any holes to plug from taking that piece off. But the large tube from that piece to the exhaust manifold can be removed also and both ends plugged. A plug at the intake-side of that tube may not be necessary, I'm not sure yet since I haven't taken that tube off as of yet.
6/1/08 -- You can also remove the white vacuum switch by the left side of the air cleaner assembly and plug the line going to the metal vacuum lines and also plug the other large line going to the air cleaner. Since the two air chamber boxes (the one on the intake and the one next to the upper timing cover) are gone, that vacuum switch is not needed either.
Stuff from the 2 black boxes on intake and next to timing cover...
Another thing you can toss in the garbage is the Anti-Afterburn Valve. Unplug the vacuum line from the AAB Valve to the metal vacuum line and plug the metal line. Then trim back the smaller lines, plug them off and toss the valve. Not needed for function of the carburetors. All it does is hold the throttle partially open when shifting.
I'll add more to this as I do them. I'll also try to get some pics posted so you guys can see exactly what I'm talking about and where. I'm only putting in the removal of stuff that doesn't adversely affect the performance/driveability of my own car. If it makes my car run like dog$&%t, then I hook it back up and consider it a needful thing to have on there...
6/1/08 -- Control box #2 located on the left strut tower...yank it off and throw it and the vacuum canisters connected to it (one below the power steering reservoir, the other is under the left headlight). Then you can plug off the lines at the metal end. You can also get rid of the little orange vacuum switch connected to it lower down on the strut tower. There's another vacuum switch with three vacuum lines on top of the strut tower. That one needs to stay, but the one vacuum line can be redone so it's just a single line--not split off to elsewhere.
Control box #2 and attatched stuff...
The vacuum line that needed to be redone...
The only good use for Autolite plugs per my past experiences...
__________________
'87 Prelude DX
Believe me, it's faster than it looks...try hanging with me in the twisties...
Aren't there like 3 people in Montana?
So that means what, 2/3rds of the population of Montana drive Preludes by my math.
fullthrottle_man is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-02-2008, 02:01 PM   #2
Roodelude2
Lude Dude
Roodelude2's Avatar
Roodelude2 is on a distinguished road
pretty much everything you see in the picture except the chair and background-NOT NEEDED
Great job on the thread fullthrottle man !!
Roodelude2 is offline   Reply With Quote Quick reply to this message
Old 06-02-2008, 02:16 PM   #3
fullthrottle_man
Lude Boss
Bump for adding pics finally... hehe
__________________
'87 Prelude DX
Old 06-02-2008, 02:52 PM   #4
MSchu
Newbie
MSchu has disabled reputation
Nice... In for reading later.
MSchu is offline   Reply With Quote Quick reply to this message
Old 06-02-2008, 04:51 PM   #5
rjudgey
Prelude Aficionado
rjudgey has disabled reputation
Prelude of the Month
Vacuum crap
Oh the joys of having a U.K. polluting machine with none of that crap on my car from standard oh yay oh yay!!!!
P.S. if anyone needs a close up of my engine bay to see what it's like without any rubbish let me know i'll send you one. Also have a couple of inlet manifolds without the holes and emiision rubbish on if anyone whats one they can have but they'll have to pay shipping etc from U.K.!!!
__________________
i like to hunt big game boy ricers are no challenge!
rjudgey is offline   Reply With Quote Quick reply to this message
Old 06-02-2008, 07:59 PM   #6
fullthrottle_man
Lude Boss
Hey Rich! Wanna post up those pics on here anyways? I can't speak for everyone, but I know I'd REALLY like to see the underhood of yours since it is already lacking the pollution control crap that our USDM Ludes all have...
__________________
'87 Prelude DX
Old 06-03-2008, 11:13 PM   #7
fullthrottle_man
Lude Boss
Another couple things that can be rid of on our cars is Frequency Solenoid Valve A and Air Control Valve A. Both are located next to each other on the right side just behind the valve cover. The solenoid valve is the black round valve with clear top and green wire connector with 2 vacuum lines going to it (pretty good sized ones too). The Air Control Valve A is the white plastic valve that is connected to the solenoid valve. Both can be tossed and the resulting lines capped off...not needed...I'll try to get a pic of them and their location tomorrow for you guys!
Frequency Solenoid Valve A....
Air Control Valve A....
And the two hooked together by the factory vacuum lines as they sit behind the valve cover on the right side.....
It's raining so I haven't gotten the pic of where exactly they sit under the hood....
__________________
'87 Prelude DX
Old 06-04-2008, 11:18 AM   #8
rjudgey
Prelude Aficionado
Engine bay
Which one this one?
Or This one?
Red one here as well.
__________________
Old 06-04-2008, 11:34 AM   #9
cygnus x-1
Elite Member
cygnus x-1's Avatar
cygnus x-1 will become famous soon enough
WTF?? Where's all the stuff?
C|
Which one this one?
Or This one?
cygnus x-1 is offline   Reply With Quote Quick reply to this message
Old 06-04-2008, 01:22 PM   #10
Prelude85
I am Prelude
Prelude85's Avatar
Prelude85 has a spectacular aura aboutPrelude85 has a spectacular aura about
Send a message via AIM to Prelude85 Send a message via MSN to Prelude85 Send a message via Yahoo to Prelude85
Wow very nice indeed. I'll sticky it.
__________________
Archaic_Entity: Rick can't ban you. He's a mod, but he's about as serious as a Mexican on Cinco de Mayo.
O.G.Luden:Is a messican god! My future kids will write songs about him. The first born wil be named Prelude85.
kayla the geezy: Tu eres mi estrella.
Prelude85 is offline   Reply With Quote Quick reply to this message
Old 06-04-2008, 06:46 PM   #11
fullthrottle_man
Lude Boss
Very nice! I'm diggin the Webers man! Got any more pics of the middle one from a couple other angles? I'm already getting ideas for more stuff to come off...(next is the vapor cannister/lines)...
__________________
'87 Prelude DX
Old 06-05-2008, 08:41 PM   #12
JDM86lude
JDM86lude's Avatar
JDM86lude has a little shameless behaviour in the past
o man y couldnt u do one for si. i know u dont have one but damn
JDM86lude is offline   Reply With Quote Quick reply to this message
Old 06-05-2008, 10:06 PM   #13
fullthrottle_man
Lude Boss
If I had one I would man! Maybe someday I'll be lucky enough to find a Si that's in my price range (cheap lol)...
Update time! The entire black box and it's contents can be ripped out and chucked! All you need to do is a little vacuum line reworking. The power valve can be hooked to manifold vacuum as well as both of the vacuum advance lines. The advance I actually hooked together with a t-fitting and ran that to manifold vacuum. Seems to be working just fine for me! The power valve also needs to run to manifold vacuum and tomorrow I'll try to get some pics of which line needs to be run to vacuum and where I ran it to. Also, the valve on the driver's strut tower (with 3 vacuum lines to it) can also be pulled off. One of those lines needs to be capped off (#22 on factory lines at the carbs), the other two I also capped off. Those two I want to do a little more investigating into as far as whether they should be going to ported vacuum or not...
__________________
'87 Prelude DX
Old 06-08-2008, 01:12 AM   #14
G2Prelude
Newbie
G2Prelude is on a distinguished road
you sir are fucking awsome!!! i shall begin my quest on monday so if you have or already have had any tragic errors or oh shit can't pull that moments please let me know..i'm gonna use this as a manual!!
__________________
1985 Honda Prelude ET2/MTX
1993 F350 CrewCab Dually-460/ATX
1985 F150 302HO/AOD
1957 Mercury Montery 312/Merc-O-Matic
G2Prelude is offline   Reply With Quote Quick reply to this message
Old 06-08-2008, 01:26 AM   #15
knifemind
Lord Magnum
knifemind's Avatar
knifemind will become famous soon enough
I began mine a while back, but I tackled the black box two days ago ... I even dismantled the box and have just attached what was left to the firewall...
One question. What can be done with the charcoal canister? (that IS the charcoal canister next to the firewall, right?) I don't need it, correct? If not, then the only lines remaining from the black box should be for the vacuum advance on the ditsro...can anyone confirm or deny this please?
__________________
knifemind is offline   Reply With Quote Quick reply to this message
Old 06-08-2008, 03:56 PM   #16
2ndGenGuy
Lude Cray
2ndGenGuy's Avatar
2ndGenGuy is on a distinguished road
Send a message via ICQ to 2ndGenGuy Send a message via AIM to 2ndGenGuy Send a message via MSN to 2ndGenGuy Send a message via Skype™ to 2ndGenGuy
You can get rid of the canister, but you'll be smelling gas in your car if you do. I found that one out the hard way. It basically collects the fuel vapors from the tank and burns them as you're driving.
__________________
2ndGenGuy is offline   Reply With Quote Quick reply to this message
Old 06-08-2008, 07:44 PM   #17
fullthrottle_man
Lude Boss
I got rid of the canister also, but I haven't had any problems of smelling gas at all since then. I left the line going to the firewall from the canister open for a vent for the tank. So far, so good! I also did a little reworking of the lines remaining. Lines #23, 24, and 25 (the 3 that went to the valve on the left strut tower) I originally capped off separately. Now, I've hooked the three together with a t-fitting and it's running like a champ! So as of now, I've basically eliminated the entire black box and it's contents, the black vacuum line box on the left strut tower, the valve there also, the black air boxes (on the intake and in front of the upper timing cover), the aluminum valve for the black air boxes, and finally got around to cutting and capping the two metal tubes from the exhaust manifold. Hopefully tomorrow it won't be raining for the first time in weeks so I can get some pics!
__________________
'87 Prelude DX
Old 06-09-2008, 02:14 PM   #18
Matthew
Newbie
Matthew's Avatar
Matthew is on a distinguished road
i want to see that done to a si fuel injection to see what it looks like at the end
__________________
3 more years than antique tag that says 86 lude cant wait
Matthew is offline   Reply With Quote Quick reply to this message
Old 06-09-2008, 09:49 PM   #19
keithmtb
Newbie
keithmtb has disabled reputation
Send a message via AIM to keithmtb
hey all. so, I'd love to do the weber conversion but can't just yet. instead I want to pull all the spaghetti vacuum lines. it looks like some of you guys have, how do I know what I can get rid of ? can you post a few pics of the set-up ?
1 year for antique tags !
__________________
84 prelude
keithmtb is offline   Reply With Quote Quick reply to this message
Old 06-10-2008, 12:05 AM   #20
cygnus x-1
Elite Member
cygnus x-1's Avatar
The first few posts tell you which things can be removed (most of it actually), but I can see how it would be confusing unless you are fairly familiar with the engine. A picture of the end result might be helpful.
And hey, you're in the Chicago area. I'm up near Six Flags.
I'm curious, why would you want antique plates? We're already exempt from emissions now.
C|
Old 06-10-2008, 07:59 AM   #21
keithmtb
Newbie
we're exempt in IL ? that's awesome, I was at the emissions joint and failed, tags pulled. the car is a 84 and seems to have extra vacuum lines for the vacuum lines, the other pics I've seen seem to have less than mine. my dad is helping out and he used to synchronize the old jaguar XK-E's in the 60's and he said those were easier to tune.
I thought the antique plates would be cheaper - as well as insurance. plus I want to hit some cruise nights and they give you a hard time if you're in the 80's.
how far are you from CLC - I auto-x there with miata club.
__________________
84 prelude
Old 06-10-2008, 04:24 PM   #22
keithmtb
Newbie
are the 87 dual crabs the same as the 84 ?
__________________
84 prelude
Old 06-10-2008, 06:29 PM   #23
knifemind
Lord Magnum
knifemind's Avatar
I busted up when I read "dual crabs."
But yeah, everything is pretty much the same. If there are any differences, they should be inconsequential in terms of what we are doing/discussing here.
__________________
Old 06-10-2008, 08:40 PM   #24
keithmtb
Newbie
carbs or crabs... Both a pain the arse right now... I'm not sure which is a bigger headache.
__________________
84 prelude
Old 06-10-2008, 10:39 PM   #25
cygnus x-1
Elite Member
cygnus x-1's Avatar
Those dual carbs are crabs as well. Not very easy to tune.
If you failed then you may not be exempt, yet. The way it works is this:
If you were in compliance as of February 2007 you should be good. If not, then you still have to be tested until it passes. After it passes it should then be exempt. When did it fail?
and such. Not that any cop would give a rip.The antique plates might indeed be cheaper. Except that you are (technically) restricted to driving to and from show events and fuel stations.
Would be funny to show up at a cruise night with a Prelude! Park between the rat rod and the '56 Bel Air!
I'm in Beach Park (basically Waukegan). I went to CLC for a few years and until recently drove by there on the way to work every day. I didn't know they did auto-x there. I've been wanting to check that out for awhile, maybe even try it myself. How often are the events?
C|
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
