DIY Slide hammer for EGR port cleaning w/ pics - Page 3 - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 02-17-2008, 12:14 PM   #51
Squad Walker
True Luder
Squad Walker's Avatar
Squad Walker is on a distinguished road
Thanks for the write up. I did this yesterday. The hardest part of the whole deal was getting those damn 12mm nuts of the EGR valve because of having not much clearance above the nuts b/c of the side of the EGR valve in the way. I didn't have a shallow socket & neither did the autozone I went to.
I ended up spraying the nuts with some PB nut blaster & let it sit for a bit. It also helps to take off the IACV valve, the fuel pressure regulator & the fuel rail before you tackle the EGR. I ended up removing the nuts with the closed end of a wrench (wasn't six sided), working the wrench in the area where the fuel rail goes. As said before, just make sure you get a good seat or you round the top of the nuts off.
I even pulled my injectors out & shoved balls of saran wrap in the injector holes to keep that nasty carbon from falling down there. Also, be careful when you remove the injectors not to loose the little O-rings at the base, each injector has two at the bottom & one small little do-hicky at the top that can slide out if you're not careful. Would suck to loose any of those in you engine bay somewhere.
This was my first time ever removing the injectors and I almost lost those o-ring pieces... also, try to make sure you keep car cleaner off of any/all gaskets O-rings, they'll swell. I got some on one injector & had a bitch of time pushing it back in the injector hole.
Also, I removed my egr ports with just a drill bit, slightly larger screws & the claw on a hammer. I skipped making/getting a slide hammer. They pulled out just fine with a nice jerk. Get a few screws if you do this, b/c you'll most likely bend a couple when jerking on the plugs.
I did this b/c I got a cel code for EGR. But, it seems to accelerate & idle smoother, also notice my engine seems to be more audible. One things for sure, I got a lot of nasty crap out of the EGR & those ports & I'm not getting a cel code anymore. Thanks again for the write up, it was extremely helpful.
__________________
[SIGPIC][/SIGPIC]
Squad Walker is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-29-2008, 01:06 PM   #52
LudaPower
LudaPower is a jewel in the roughLudaPower is a jewel in the roughLudaPower is a jewel in the rough
Just did this today. Egr ports were all completely clogged.
Went alright except for when I lost one of the three fuel rail spacers.. Never found it and ended up making a new one using a bunch of washers.
Used a wrench to take out the egr valve, fairly easy.
LudaPower is offline   Reply With Quote Quick reply to this message
Old 03-29-2008, 09:53 PM   #53
Aderks
True Luder
Aderks's Avatar
Aderks is on a distinguished road
Feel any difference? When i did mine I didn't feel that much of a difference. Who knows.
Aderks is offline   Reply With Quote Quick reply to this message
Old 03-30-2008, 05:25 AM   #54
LudaPower
Not really, maybe smoother acceleration, but I can't really tell.
Old 04-09-2008, 01:32 AM   #55
AkumaR6
Lude Dude
AkumaR6's Avatar
AkumaR6 will become famous soon enough
Good points you made. One of my o-rings was a pain to get back in the injector bore since I think I got a tiny bit of carb cleaner on it.
I noticed the exact same thing. It idled a tad smoother, felt smoother while accelerating, and the engine just sounded a little better overall afterwards. Nothing dramatic, but just a little. I was amazed at how much nasty crap came out of there and thankfully I won't have to do it again for quite some time, if ever again. The code never came back, either.
And all of you guys that said thanks are welcome, I'm glad it helped.
__________________
SOLD - 2001 Honda Prelude - JDM Fogs, RSX-S Wheels - Now featuring cleaned EGR ports:
SOLD - 2003 Yamaha R6
Do NOT trust jesus98lude cuz he will not pay you "when he gets the money" like he promised. He went and sold the rims, yet he never has the money. I will remove this if he ever pays me
AkumaR6 is offline   Reply With Quote Quick reply to this message
Old 04-26-2008, 05:12 PM   #56
grego
Lude Addict
grego's Avatar
grego is an unknown quantity at this point
Is it safe for the engine to be spraying Carb Cleaner through the EGR plug location? Should one do an oil change after this? Or something?
__________________
grego is offline   Reply With Quote Quick reply to this message
Old 04-26-2008, 05:15 PM   #57
viper_boy403
Vrooom PSHHHH
viper_boy403's Avatar
viper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to behold
Send a message via AIM to viper_boy403
I dunno but I did it lol. I didnt use too much though, and the stuff that pooled I soaked up with a rag I stuck down the hole. No problems starting it up afterwards, no stumbling or weird idle or anything. Anything that gets into the combustion chamber should just get burned off immediately anyways
__________________
- Competition Clutch - MFactory - Prosport - Skunk2 - Neptune - Innovate - Seibon - H&R- KYB - Tial - Injector Dynamics -
- Energy Suspension - Vibrant - Aeromotive - Synchrotech - Quaife - GE - Hawk - Innovative Mounts - CP - Eagle -
BOOSTED
1997 San Marino red base
-Andrew-
Fuck bitches... acquire boost.
viper_boy403 is offline   Reply With Quote Quick reply to this message
Old 04-27-2008, 10:07 PM   #58
ulanky
Lude Cray
ulanky's Avatar
ulanky is on a distinguished road
I must've used about two cans of this shit in my ports, but I blew it out with an air compressor and was perfect.
ulanky is offline   Reply With Quote Quick reply to this message
Old 04-28-2008, 04:57 PM   #59
grego
Lude Addict
grego's Avatar
i has no air compressor
__________________
Old 04-28-2008, 05:11 PM   #60
viper_boy403
Vrooom PSHHHH
just stick a rag down there and soak up the residual carb cleaner. It will be fine. Make sure to replace the gasket as well, if it's bad that is.
__________________
BOOSTED
-Andrew-
Old 04-28-2008, 05:14 PM   #61
LudaPower
There's a reason they use carb cleaner.
It's flammable. It burns. It's kinda like gasoline. The engine will burn it.
Ever make a fire in your backyard all the while drunk and decide to test stuff in the garage that burns the most?
Carb cleaner is one of the best for that
Old 04-28-2008, 05:33 PM   #62
grego
Lude Addict
grego's Avatar
uh, what gasket? I was talking about cleaning egr ports...
__________________
Old 04-28-2008, 05:35 PM   #63
grego
Lude Addict
grego's Avatar
from reading the ABOVE, it seems as thought i am to be removing my FUEL RAIL, FPR, and INJECTORS in addition to my EGR valve and PLUGS. is this all necessary?
__________________
Old 04-28-2008, 06:07 PM   #64
viper_boy403
Vrooom PSHHHH
I was referring to the gasket on the actual EGR valve.
__________________
BOOSTED
-Andrew-
Old 04-28-2008, 06:15 PM   #65
Preludedacris
Ludacious
Preludedacris's Avatar
Preludedacris is on a distinguished road
I didn't see a gasket for my egr valve!!
__________________
: Body is Complete,
: Got Projectors and Hids, Need the retrofit!
Preludedacris is offline   Reply With Quote Quick reply to this message
Old 04-28-2008, 07:47 PM   #66
prelude100
Lude Dude
prelude100 is on a distinguished road
Exclamation
very good write up. thank you.
i have cleaned the EGR valve already, but 1 question though. For remove the old plug, i still unclearify about it. What is the easy way to take it off? drill it? its my first time, so i dont want to screw up.
prelude100 is offline   Reply With Quote Quick reply to this message
Old 04-28-2008, 07:55 PM   #67
viper_boy403
Vrooom PSHHHH
if you couldn't tell it was there then it's probably fine lol. mine didnt look like a gasket anymore, it was all flattened out haha. it was all in one piece still so i just left it.
__________________
BOOSTED
-Andrew-
Old 04-30-2008, 02:15 AM   #68
TheJGB3
Ludacious
TheJGB3's Avatar
TheJGB3 will become famous soon enoughTheJGB3 will become famous soon enough
Very nice write up. I talked to a Honda tech at a Honda dealer and he recommended using a "top engine cleaner" instead of carb/choke cleaner. He said "go to a GM dealer and buy CLEEN or a Mopar (Dodge/Chrysler) dealer and buy MCCC (Mopar Combustion Chamber Cleaner. He said this stuff "just instantly melts the carbon into liquid"
__________________
AEM SRI & brake pads
JDM Type S frt & Megan Racing rr strut bars
OEM lip kit
OEM CF trim kit & JDM CF gauge bezel
JDM Foglights w/USDM switch
JDM Type S red-stitched seats, shift knob, steeringwheel
Clear front sidemarkers w/ Amber LED bulbs
polyurethane motor mount inserts
ASE Re-Certified Technician
Suspension and Steering (A4)
Brakes (A5)
Heating and Air Conditioning (A7)
Exhaust System Specialist (X1)
Automobile Parts Specialist (P2)
Automobile Service Consultant (C1)
TheJGB3 is offline   Reply With Quote Quick reply to this message
Old 05-01-2008, 01:19 PM   #69
AkumaR6
Lude Dude
AkumaR6's Avatar
I suppose there is some way to get it done without removing all of that, but I really didn't see one. Also, it takes literally 5 minutes tops to remove the IAC, fuel rail, FPR, and the injectors. You don't need to remove the line from the rail, you just unbolt it and swing it out of the way. Spending a few minutes to remove those will make the whole thing much, much easier I guarantee it.
Thanks. Yeah, just drill a hole straight through it and use a vacuum every now and then to suck up the shavings. Then tap threads into the hole and then remove the plugs. They aren't in there too hard if you get a good hit with the slide hammer. A few of them I removed completely in one hit.
__________________
Old 05-01-2008, 01:25 PM   #70
AkumaR6
Lude Dude
AkumaR6's Avatar
I'm glad you mentioned this since mine didn't have one either and I know they sell them at parts stores so maybe someone had it off before or it didnt get put on at the factory. I didn't have one at the time and I needed the car running again the same night so I put it back on without one. I might put one on next time I need to do something under the hood.
Thanks for the tip. The carb cleaner liquified the carbon, but it took a few sprays. One of the guys on the boards asked me to help with their EGR ports and I think I will tell him to use the top engine cleaner instead.
__________________
Old 05-02-2008, 03:34 PM   #71
grego
Lude Addict
grego's Avatar
im not really understanding the actual Slide Hammer that you made.
What connects the rod to the plugs? Slide hammers from the store clamp onto the nail/screw
Are you screwing the rod the from slide hammer directly into the plug? If so, how?
That and even the construction of the DIY Slide Hammer I don't find very clear, you listed the parts, but didnt explain how to put them together.
I don't really get it. Trying to get this done this weekend, and i could use some help...
__________________
Old 05-13-2008, 10:52 PM   #72
AkumaR6
Lude Dude
AkumaR6's Avatar
Correct. The rod from the slide hammer screws into the plugs since I tapped threads into them. That is also the way shown in the Honda TSB. Their method uses a normal slide hammer, but with a bolt that screws into the EGR plugs after they are tapped. Also, I explained how to put the parts together. You just drill holes into the center of the caps big enough for the rod to fit through and then just screw the caps onto the ends of the pipe. That's really all there is to it. Then just slide the rod straight through the pipe and caps and screw a nut onto the end of the rod so that the "hammer" has something to slam against when you use it. If you have access to a normal slide hammer that can clamp onto a bolt then I would use that, but nobody in town had them at the time and plus this was cheap and worked flawlessly. I hope this helped explain it somewhat better.
__________________
Old 05-14-2008, 04:59 PM   #73
grego
Lude Addict
grego's Avatar
yeah, i was just being retarded. Everything went smoothly! the DIY Slide Hammer worked great!
__________________
Old 05-20-2008, 02:04 PM   #74
lslos
Getting Comfortable
lslos's Avatar
lslos is on a distinguished road
I am new to this site and I have a problem with my egr system. right now i have the vacuum line that connects to the EGR disconnected because when I have it pluged in it will not release the valve after opening it. Does anyone know why? I switched out my egr solenoid with three others from H22 engines and they are providing vacuum under load but it leaves the vavle open. Anything will help.
lslos is offline   Reply With Quote Quick reply to this message
Old 06-16-2008, 04:02 AM   #75
jhill110
Newbie
jhill110 is on a distinguished road
Thanks for The Great Write-Up
jhill110 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
