DIY Slide hammer for EGR port cleaning w/ pics - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 09-12-2007, 01:05 AM   #1
AkumaR6
Lude Dude
AkumaR6's Avatar
AkumaR6 will become famous soon enough
I saw a few posts where people were looking for a slide hammer to remove the EGR port plugs. Most people I asked don't even know what a slide hammer was and I didn't see one that would work from harbor freight. I didn't feel like buying the honda one, so I made my own for about 6-8 bucks total from Home Depot and figured I would post up what I did in case someone else wanted to try it as well. I'm also going to include a bunch of pictures from the cleaning since I saw people asking about pics from inside the ports and how they look dirty vs clean. I wish I could have seen some beforehand, but here they are for anyone that wants to see them.
The materials used:
8" x 1 1/4" pipe, 2 matching caps, 2' or so of 10-24 threaded rod, nuts, and a washer that was bent for strength. This was probably overkill since the nuts would have been strong enough on their own, but I had no idea how much force would be needed to remove the plugs. It really isn't that much. Drill a hole in the center of each cap just slightly big enough so the rod can fit through. I went to the self checkout lane. Probably a better idea since it will keep them from giving you the "you aren't making a pipe bomb, are you?" look.
Assemble as shown:
The end result. In retrospect the rod was maybe a bit long, but again I didn't know how much force would be needed. If you look closely you can see one of the plugs on the end of the rod.
The old plugs:
I bought a pack of 10 plugs just in case I needed extras:
Comparison shot:
I wish I had seen a better shot of the old plugs since I figured mine were different. I didn't know they were solid brass instead of aluminum cups like the replacements. Hopefully this will let people see the difference in case they wonder also.
Ok, on to the cleaning...
I simply removed the EGR valve, IAC valve, FPR, and the fuel rail. A bit of coolant will spill when removing the IAC, but nothing to worry about. Also, it wasn't even necessary to remove the banjo bolt on the fuel rail, you can just remove the three nuts holding the rail on and swing it out of the way.
The two nuts on the EGR were hard to crack loose. I just used a 12mm shallow socket and a swivel with an extension, but ONLY to crack them loose since the swivel was hitting the lip on the EGR valve. Just make sure the socket sits flush or else you could damage the nut. I switched to a 1/4" drive socket and extension and it cleared just fine.
On the IAC there are two 12mm bolts holding it on. A wrench is the best way to get at them. The bottom bolt was hard to get out since it was hitting the fuel rail but with enough wiggling and some magic it came out. The shorter bolt goes on the bottom, the longer bolt goes on top when putting it back on.
The FPR is held on by two small 10mm bolts. I am pretty sure you have to have it out of the way to get at the last nut on the fuel rail. I almost bolted the FPR back down but I realized there was no way to get the nut back on with it in the way.
The fuel rail is held on with 3 10mm nuts and it just lifts off the studs. You can swing it out of the way instead of removing the banjo bolt. I also opted to leave the injectors in and cover them up since taking them out would leave 4 big holes wide open and would be too much work trying to make sure they stayed covered with carb cleaner and compressed air flying everywhere.
As for the plugs, just drill into them with a #25 drill bit like in the TSB, and tap them with a 10-24 tap. You can vacuum away the shavings as you drill. Honestly I don't even think it should be a problem considering the ports are so clogged that the shavings wouldn't even fall down into them, but if you still feel like you should vacuum it won't hurt anything.
The culprit. One engine with filthy EGR ports:
The engine looks clean, but don't let that fool you...these things were terrible.
Solid carbon buildup:
Dirty ports even after a bit of cleaning:
Here's one port after a bit of cleaning with the brass wire and carb cleaner. Looking better but still not good enough yet:
These should connect to each other, but it took a bit of poking with the wire, blowing compressed air, poking, more air, carb cleaner, poking, more air, etc:
In the process of cleaning:
Getting there:
...aaaaand done:
As others have said it should look like shiny aluminum with a hole at the bottom. The crossover ports should be clean. You can test this by spraying carb cleaner in one direction down the crossover port and seeing if it runs into the other port. You could also blow compressed air down one port and feel for air coming out the other. That would be much less messy. Also, check to see if its clean between the rectangular part of the EGR and the first port. On mine it was clogged badly and I'm glad I checked before putting everything back together. It took a bit of letting the carb cleaner soak and poking away on the buildup running between the ports.
EGR valve cleaned:
Plugs installed:
All the discoloration is the splatter from the carb cleaner mixed with carbon buildup. Spray some cleaner on a rag and it will wipe right off.
The plugs should sit flush with the intake as shown:
Hopefully this will help someone out who is preparing to do this themselves and wants to see exactly what they will be dealing with. Start to finish you could have it done in an hour if you've done it before, but I think that's really pushing it since to really clean the ports out it takes time. The whole disassembly and reassembly combined took maybe 15 minutes at most. The drilling/tapping took maybe another 10-15. I spent a good 2-3 hours cleaning the ports out since I don't plan on doing this again any time soon. At least not on this lude anyways. I figured since everything was apart, why not clean it out as best I can.
It's really not that hard to do yourself, especially if you are familar with cars. It's just a pain in the ass leaning over the wide fenders trying not to scratch them and not get carb cleaner on the paint when it's flying out of the ports. I covered everything with towels and newspaper just in case. I didn't trust any shop to do this correctly even though I know there are a few that would. I wanted to know that the ports were clean instead of just drilled out, poked with a wire once, and plugged again. Also, there was no worrying about when it would be finished at a shop or if they would scratch the paint, etc.
If this helps even one person then I'm glad I posted it.
-Brad
__________________
SOLD - 2001 Honda Prelude - JDM Fogs, RSX-S Wheels - Now featuring cleaned EGR ports:
SOLD - 2003 Yamaha R6
Do NOT trust jesus98lude cuz he will not pay you "when he gets the money" like he promised. He went and sold the rims, yet he never has the money. I will remove this if he ever pays me
AkumaR6 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-12-2007, 02:28 AM   #2
Aderks
True Luder
Aderks's Avatar
Aderks is on a distinguished road
Good Write up on the port cleaning. I bought the plugs but everywhere I went no one knew what a slide hammer was or these were all sold out.. figures.. Imm glad this worked out... I just need to manage some time to get mine cleaned. Thanks again for the write up.
Aderks is offline   Reply With Quote Quick reply to this message
Old 09-12-2007, 07:33 AM   #3
1998prelude
Ludacious
1998prelude's Avatar
1998prelude is on a distinguished road
EXCELLENT write-up!! Rep points for you! Also, you did an excellent job cleaning the ports out. As soon as i figure out the problem with my H22A swap im going to be cleaning the engine a bit and this is def a priority!
__________________
yea, you have to wait 120 days until it will start, i believe a ninja lets go of the CYP sensor.
1998prelude is offline   Reply With Quote Quick reply to this message
Old 09-12-2007, 07:45 AM   #4
cvpreludesh
Lude Addict
cvpreludesh's Avatar
cvpreludesh is on a distinguished road
Send a message via AIM to cvpreludesh
that was an awesome write up way to be innovative and make your own tools!!
__________________
JDM H22 TYPE S!!!!!
cvpreludesh is offline   Reply With Quote Quick reply to this message
Old 09-12-2007, 11:39 AM   #5
Buddyclub98
True Luder
Buddyclub98 is on a distinguished road
Pimp writeup man! How many miles on your odometer? I'm thinkin I may need to do this pretty soon.Needs to be in the articles section, excellent pics too.
Buddyclub98 is offline   Reply With Quote Quick reply to this message
Old 09-12-2007, 12:09 PM   #6
viper_boy403
Vrooom PSHHHH
viper_boy403's Avatar
viper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to beholdviper_boy403 is a splendid one to behold
Send a message via AIM to viper_boy403
very nice writeup! ive heard of doing this before, but cant exactly remember the point?
__________________
- Competition Clutch - MFactory - Prosport - Skunk2 - Neptune - Innovate - Seibon - H&R- KYB - Tial - Injector Dynamics -
- Energy Suspension - Vibrant - Aeromotive - Synchrotech - Quaife - GE - Hawk - Innovative Mounts - CP - Eagle -
BOOSTED
1997 San Marino red base
-Andrew-
Fuck bitches... acquire boost.
viper_boy403 is offline   Reply With Quote Quick reply to this message
Old 09-12-2007, 12:11 PM   #7
FyVe
Lude Boss
FyVe's Avatar
FyVe will become famous soon enough
Send a message via AIM to FyVe
good write-up.
i just used a screw and drilled into the caps then the backside of a hammer to pull them out...
__________________
SOLD!!
FyVe is offline   Reply With Quote Quick reply to this message
Old 09-12-2007, 12:40 PM   #8
fastkill
Ludacious
fastkill's Avatar
fastkill is on a distinguished road
Have you noticed any thing performance wise yet?
__________________
fastkill is offline   Reply With Quote Quick reply to this message
Old 09-12-2007, 12:52 PM   #9
Bobo_686
Chatbox Whore
Bobo_686's Avatar
Bobo_686 will become famous soon enough
Send a message via AIM to Bobo_686
x2 i was wondering the same thing
__________________
for Garage!
RIP SEAN TAYLOR #21...YOU WILL BE MISSED...
God needed a safety on his team..
Bobo_686 is offline   Reply With Quote Quick reply to this message
Old 09-12-2007, 02:46 PM   #10
AkumaR6
Lude Dude
AkumaR6's Avatar
Originally Posted by brazillianpimpx View Post
good write-up.
thanks. it was your write-up that made me decide to hurry up and get it over with since every time i reset the CEL it would come back on during the very next tank of gas. i figured i would try and get a few pics that i felt might add to the write-up you did. i felt uneasy about using the hammer to pry them out since i didnt want to put a lot of force on those parts but if i couldnt find another way thats what i would have done.
if you arent throwing a code for it, then i wouldnt worry about it yet. basically the point is to clean out the ports that allow EGR to flow through the intake. it serves to allow your car to use less fuel during light throttle applications such as doing a constant speed on the highway, etc, by letting the car use a leaner mixture. it wont detonate since the EGR system adds inert gases to the combustion chamber to lower temps. at idle and WOT it stays closed and plus at WOT your computer doesnt even take into account the oxygen sensor readings.
__________________
Old 09-12-2007, 02:49 PM   #11
AkumaR6
Lude Dude
AkumaR6's Avatar
thanks. it started throwing the CEL at 92 or 93k. judging by how much build up was in there i would say that it wouldnt be a bad idea to do this at 75k or so. unless its throwing a code you could probably hold off, but it wouldnt hurt to clean them early.
well since the EGR doesnt function at idle and WOT it might at first seem like this didnt do anything. i forget if it functions before the ECM goes into closed loop or not, but i dont think it does...i could be wrong. however there was an audible difference throughout the rev range once the car reached operating temp, it sounded a bit smoother..especially during highway driving. i just filled up the tank and am going to see if my mileage changes. i was already getting 360 to 380 a tank but i dont know if it will get much higher than that anyways. the 360 was more common, though. i will keep you guys posted.
__________________
Old 09-12-2007, 02:56 PM   #12
AkumaR6
Lude Dude
AkumaR6's Avatar
thanks, man. is your lude silver? i cant quite tell from the avatar. i wonder if ive seen it around town before.
thats the same problem i ran into. instead of spending an hour on the phone explaining what it was to parts places in town i figured i could go make one in half that time. the weight of the pipe and caps was just about perfect for the force needed to get the plugs out. its kinda ghetto, but it worked great.
__________________
Old 09-12-2007, 04:55 PM   #13
ENFORCER99
True Luder
ENFORCER99's Avatar
ENFORCER99 is on a distinguished road
holy shit 360- 380 a tank im lucky if i get 260 to a tank, its all city driving but damn
ENFORCER99 is offline   Reply With Quote Quick reply to this message
Old 09-12-2007, 09:27 PM   #14
daluder
Lude Boss
daluder's Avatar
daluder is on a distinguished road
im subscribing to this. Thanks man..great writeup!
__________________
2008 World Series Champions Philadelphia Phillies
holy sh*t..holy sh*t..
daluder is offline   Reply With Quote Quick reply to this message
Old 09-12-2007, 09:56 PM   #15
94si2nr
Ludacious
94si2nr is on a distinguished road
this needs to be put in the resource thread. rep for you
__________________
[COLOR=Red]1/4 mile @ 15.3 @ 90 mph
94 Si (sold) , 93 Si (Restored then sold), 99 Base (My Baby), 06 Honda S2000 (My other baby),04 Honda Pilot EX-L Touring (The family vehicle/DD)
94si2nr is offline   Reply With Quote Quick reply to this message
Old 09-12-2007, 11:20 PM   #16
FaV605
HOME GROWN HOMIE
FaV605's Avatar
FaV605 will become famous soon enoughFaV605 will become famous soon enough
Send a message via AIM to FaV605
nice write up. and very clean engine bay.
__________________
BIG MIKE >
< FRANK
hit me up for any vinyl decal needs!
FaV605 is offline   Reply With Quote Quick reply to this message
Old 09-12-2007, 11:37 PM   #17
drivinvtec
Lude Addict
drivinvtec's Avatar
drivinvtec is on a distinguished road
Send a message via AIM to drivinvtec Send a message via MSN to drivinvtec Send a message via Yahoo to drivinvtec
what is the point of this??
__________________
My Spelling Sux, I noe
2001 Prelude...turboed
Your like the luckiest fool I've ever known.... sand storm= free paint and windows.... now you bust your value keeper and dont bust a hole in your piston just at the time you pull it and rebuild...........
i mean damyn if i was you id go by and get a lotto ticket!!
drivinvtec is offline   Reply With Quote Quick reply to this message
Old 09-13-2007, 12:27 AM   #18
Preludewhore
True Luder
Preludewhore is on a distinguished road
wow. great write up. Thanks for sharing. Thumbs up for the pics!
__________________
-Danny
they are four lungs i only have two of them and they are 15's - urgordito3412
Preludewhore is offline   Reply With Quote Quick reply to this message
Old 09-13-2007, 08:06 AM   #19
fei8lo
Ludacious
fei8lo's Avatar
fei8lo is on a distinguished road
Send a message via AIM to fei8lo
what code was it throwing and what benefit does doing this have?
fei8lo is offline   Reply With Quote Quick reply to this message
Old 09-13-2007, 08:58 AM   #20
flylwsi
REST IN PEACE
flylwsi's Avatar
flylwsi will become famous soon enoughflylwsi will become famous soon enough
Send a message via AIM to flylwsi
Prelude of the Month
do you guys read at all?
he explains what the point is as well as benefits...
the code is most likely the EGR code... but i'm sure a bit of searching would help you out there...
__________________
GPS lap timers... 10% off w/code: 4280f1
antypoetry: i can't help it
heyfrench: nah, they're retards
heyfrench: and they make you have to be a dick
flylwsi is offline   Reply With Quote Quick reply to this message
Old 09-16-2007, 03:57 AM   #21
Aderks
True Luder
Aderks's Avatar
Quick question about this. Do you drill all the way through the plug and then tap the plug? Or do you just drill say 1/2 way and then tap it? I will be doing this soon, as Im going to the Depot tommorow.
Old 09-16-2007, 10:24 AM   #22
88si01sh
Lude Cray
88si01sh's Avatar
88si01sh will become famous soon enough
Awesome write up, rep points for you!
__________________
88si01sh is offline   Reply With Quote Quick reply to this message
Old 09-18-2007, 03:42 PM   #23
AkumaR6
Lude Dude
AkumaR6's Avatar
Sorry for the late reply, I was out of town the past few days. I think it would be best to drill completely through them just to make sure you can tap plenty of threads to keep them from stripping. Although if you drilled halfway through it would eliminate the worry of shavings falling into the ports since it wouldn't make a hole all the way through. This might not be a bad idea, actually. If the threads from drilling only halfway down or 2/3 down did strip, you could always drill and tap to the next larger size.
Thanks
__________________
Old 09-18-2007, 03:48 PM   #24
Aderks
True Luder
Aderks's Avatar
Thanks for the reply. I just did this on Sunday. I just drilled through the whole thing because it really isnt that big. I used vaseline on the bit to catch shavings but when i tapped it some shavings got in but i vacummed it out.
Instead of using that big pipe I just used 3/4 X 6 and about 1.5 feet of thread. Everything went really good until I fouled out my sparkplugs.... I guess there was too much carb cleaner maybe.. Who knows its all good now!!
THanks again.
Old 09-21-2007, 12:31 AM   #25
ulanky
Lude Cray
ulanky's Avatar
ulanky is on a distinguished road
Couple of questions.
Did you take the hood off to do this?
Did you drill all the way through?
How do I tap the holes through the tops?
ulanky is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
