HOW TO: H22 Auto Tensioner to H23 Manual Tensioner Conversion - Page 3 - Honda Prelude Forum : Honda Prelude Forums
Reply
Thread Tools Display Modes
Old 06-29-2007, 01:26 PM   #51
juiced
Getting Comfortable
juiced's Avatar
juiced is on a distinguished road
Originally Posted by jdm3genprelude View Post
hey juiced. when you have the belts on please take pics... i have not got my problem resolved yet. thebalance shaft pulley. cant figure out how its suppose to line up. i see 2 markings on my balancer pulley thats to the right of the crank and below the water pump. 1 marking is on the outer edge looks like an indentation dot. and the other marking is a notch cut out on the innner edge of the gear looks like a v shape.
Hey, I already put mine back together so I dont have pics but I do have a writeup that tells you how to set your front and rear balancer shaft pulleys (its also in the Helms). PM me with your email and Ill forward it to you.
juiced is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-29-2007, 01:31 PM   #52
cinci-91-H
Guest
Posts: n/a
May I also get a copy of that pm?, I already have mine back together, but I had some confusion on the rear balancer as well, the motor idles and runs real smooth, but I wouldn't mind comparing what I have. Thanks for all the info and the pic.............that motor looks very clean!
Old 06-29-2007, 06:39 PM   #53
juiced
Getting Comfortable
juiced's Avatar
Sure just PM me with your email. I also uploaded the writeup here;
http://www.megaupload.com/?d=0VMRP2XG
Hopefully everyone can get to it now.
Old 06-29-2007, 08:02 PM   #54
jdm3genprelude
Ludacious
jdm3genprelude's Avatar
jdm3genprelude is on a distinguished road
thank u thank u. i justpm'ed u with my email. the stupid thing is my CHILTON MANUAL doesnt say how to set it. it just stated that i had to mark it before i start taking it off which i did but it smudged off.
jdm3genprelude is offline   Reply With Quote Quick reply to this message
Old 10-28-2007, 08:40 AM   #55
Rash
I am Prelude
Rash's Avatar
Rash is a jewel in the roughRash is a jewel in the roughRash is a jewel in the rough
I'm not sure if it has been mentioned in this thread or not, but if you plan on getting rid of the balancer shafts/belts, just use PN: 92510A826 (aluminum spacer) from McMaster-Carr (mcmaster.com). This works perfectly instead of the heavy h23 balancer shaft tensioner, or reusing the equally heavy h22 balancer shaft tensioner with washers. Saves more than a couple bucks too (if you decide to buy the h23 balancer shaft tensioner)! Over 30 bucks saved! This was originally the idea of "skrewdlude" from honda-tech. Hats off to you my friend..
A picture of my conversion with the McMaster spacer...
Very lightweight aluminum and sexy! Some specs on the piece from McMaster-Carr if you decide to find your own somewhere else....
Desc: Aluminum Unthreaded Round Spacer
Size: 1" Od, 1" Length, 1/2" Screw Size
__________________
JTC Customs
Rash is offline   Reply With Quote Quick reply to this message
Old 10-30-2007, 12:37 AM   #56
jdm3genprelude
Ludacious
nice but i thought it was mandatory to have the other 2 pulleys on the sides turning...i saw the write for converting not to use balance belt but for some reason my mind said not to read it. lolz
Old 11-13-2007, 08:46 PM   #57
e.murallo
Elite Member
e.murallo is on a distinguished road
Can i get these parts at a junk yards?
__________________
I'm waitin' on the green, like I'm sittin' at a red light -loso
e.murallo is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 09:47 PM   #58
tacticalcustoms
Lude Cray
tacticalcustoms's Avatar
tacticalcustoms is on a distinguished road
hell ya. I got mine for 5 bucks
__________________
Engine mod - I/H/E(3") - Fidanza 8Lb, Exedy Stg1 - coming soon ECU and TUNE.
tacticalcustoms is offline   Reply With Quote Quick reply to this message
Old 11-17-2007, 09:31 AM   #59
rearviewmirror
Ludacious
rearviewmirror's Avatar
rearviewmirror will become famous soon enough
Send a message via AIM to rearviewmirror Send a message via MSN to rearviewmirror Send a message via Yahoo to rearviewmirror
Originally Posted by 98vtec View Post
i dont see the need in retightening unless something out of the ordinary happens. The belt will eventualy stretch enough to where you may need to retighten, but i dont see that happening anytime soon with a new belt.
I've read this whole thread and still don't hear much talk about the maintenance of the MANUAL tensioner. You said you didn't see the need to adjust it, if that was the case then Honda would have put a manual tensioner on all cars and just called it out on the 30k, 60k, or 90k service interval to check the belt tension. I can't imagine there is any advantage to going manual on a stock engine or even an engine w/ a few mods. On the flip side of that, my Ducati runs a kevlar timing belt w/ manual adjustment and once I set it I don't ever mess with it. Of course I can't compare the pressure/load on the each belt and the Ducati doesn't do anywhere near the miles the Honda does.
So in short, how are you guys actually measuring tension on the belt, and how often do you feel compelled to check it?
__________________
Straights are for fast cars, curves are for fast drivers.
Prelude StockProjekt - Daily Driver SOLD
Lexus ES300 StockProjekt - Daily Driver II SOLD
SL2 Bad Weather Beater SOLD
4Runner Mountain Bike Hauler SOLD
Ducati 996 Track Scratcher SOLD
Before you ask a question about
rearviewmirror is offline   Reply With Quote Quick reply to this message
Old 11-17-2007, 09:47 AM   #60
98vtec
bangin' gears
98vtec's Avatar
98vtec is a name known to all98vtec is a name known to all98vtec is a name known to all98vtec is a name known to all98vtec is a name known to all98vtec is a name known to all
Prelude of the Month
if a manual tensioner back off on tension, then it needs to be replaced. You shouldn't ever have to retension the belt unless doing work on the timing belt. Using a manual tensioner is just added insurance, not to mention that it lasts longer and is much easier to work with than an auto tensioner
__________________
Instagram @850Fabrication
98vtec is offline   Reply With Quote Quick reply to this message
Old 11-17-2007, 09:51 AM   #61
rearviewmirror
Ludacious
How do you accurately measure the tension w/o a special tool? Or did you purchase one?
__________________
Old 11-17-2007, 10:04 AM   #62
98vtec
bangin' gears
98vtec's Avatar
i was told by a reputable source that you should be able to flip the timing belt 90*. I held the intake gear with a 14mm wrench, turned the crank counter clockwise and tightened the tensioner.
__________________
Old 11-17-2007, 10:07 AM   #63
rearviewmirror
Ludacious
Flip it 90 degrees between which pulleys?
__________________
Old 11-17-2007, 05:24 PM   #64
Rash
I am Prelude
Rash's Avatar
My guess would be between the exhaust cam and the crank pulley. Usually deflection is measured between the pulleys that are the farthest apart.
__________________
JTC Customs
Old 11-17-2007, 05:30 PM   #65
preludeprimo
Lude Addict
preludeprimo's Avatar
preludeprimo will become famous soon enough
I was going to do a manual swap. but I got a discount on a auto tensioner and pulley. o well
__________________
JDM H22A
ON SPRAY
preludeprimo is offline   Reply With Quote Quick reply to this message
Old 12-23-2007, 09:13 AM   #66
Abuddha
Getting Comfortable
Abuddha has disabled reputation
Send a message via AIM to Abuddha
SHAZAAM!! http://www.importrp.com/product.php?productid=41997
__________________
Abuddha is offline   Reply With Quote Quick reply to this message
Old 03-06-2008, 09:53 AM   #67
JLude
Idiotic Thread Locker!
JLude's Avatar
JLude is just really niceJLude is just really niceJLude is just really niceJLude is just really nice
Send a message via AIM to JLude
Update on my timing belt job:
Held up by the Crank Pulley Bolt! 28" breaker bar and probably 300 ft lbs of torque will not budge it! Fortunately I hadn't taken that much apart on the car because now I have to drive it into EagleEye's shop and have him put an impact wrench on it.
Tip: Have your crank pulley bolt broke loose at a shop BEFORE you begin your T-belt job at home. Trust me.
__________________
Building your custom HID Projector RETROFITS since 2005! PM FOR DETAILS.
Former 5th, 4th and 3rd gen Prelude owner. Current: 2004 Toyota Tundra V8 DC 4x4, '00 Civic LX beater, '06 Yamaha FZ6S, '07 Victory Kingpin - Still a Prelude enthusiast!
JLude is offline   Reply With Quote Quick reply to this message
Old 03-06-2008, 09:59 AM   #68
tacticalcustoms
Lude Cray
lol. jlude. thats so true. I tried 3foot breaker bars. 75lb impact gun. 300ft gun and finally couldn't do anything. so my friends dad from honda came over with a impact gun called Earthquake puts out 1000+ft tq. that sucker came right off!
__________________
Old 03-06-2008, 10:10 AM   #69
JLude
JLude's Avatar
I actually didn't mean to post that in this thread. heh.
__________________
Old 03-06-2008, 10:14 AM   #70
Rash
I am Prelude
Rash's Avatar
I used that special crank pulley tool, with two breaker bars, two eight foot pipes, and two 230lb guys.
And even that took about 5 minutes.
Hardest part was the engine was sitting on a wooden pallet at time.
__________________
JTC Customs
Old 03-06-2008, 12:43 PM   #71
fastkill
Ludacious
fastkill's Avatar
fastkill is on a distinguished road
got damn crank pully bolt. Shit What is the torque spec on this fucking thing?
__________________
fastkill is offline   Reply With Quote Quick reply to this message
Old 03-06-2008, 01:01 PM   #72
JLude
JLude's Avatar
I think the spec is in the 150 Ft Lb neighborhood.
__________________
Old 03-06-2008, 06:48 PM   #73
jlude90
I am Prelude
jlude90 will become famous soon enough
y'all sound like a bunch of girls, i had a hammer and a 1/2" ratchet and got it off in about 2 minutes
__________________
Originally Posted by 98VTEC
Its a bunch of fruitcakes in a pie that doesnt mix, with no baking experience.
jlude90 is offline   Reply With Quote Quick reply to this message
Old 03-08-2008, 08:17 AM   #74
JLude
JLude's Avatar
Does anyone know what this part is for? It came with my manual tensioner kit but no mention of this bracket is shown in this DIY?!!! According to the parts list this is 14521-P14-A00 - PLATE, ADJUSTER But what does it do? Where does it go?
EDIT: I answered my own questiong by reading this entire thread:
That bracket goes where the old autotensioner was.
__________________
Old 03-08-2008, 08:42 AM   #75
prelude1897
prelude1897's Avatar
prelude1897 is a jewel in the roughprelude1897 is a jewel in the roughprelude1897 is a jewel in the rough
Send a message via AIM to prelude1897
I'm going to have to do this pretty soon for my other motor
__________________
97 Prelude-wrecked
00 Prelude-daily driver
99 Prelude-RHD Prelude
98 Prelude-Parts Car-SOLD
97 Prelude-RHD project#2
99 Prelude-Parts car-SOLD
01 Prelude-Parts car-SOLD
94 Prelude-VTEC status-Traded
98 Prelude-traded for 94 prelude
97 Prelude-Parts car-SOLD
Retrofit Service PM me
prelude1897 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Security Question
Insurance
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
PreludePower Forums
