B20A water pump and mount bracket problem - Honda Prelude Forum : Honda Prelude Forums
Old 04-18-2017, 11:24 AM   #1
tavo_80816
tavo_80816's Avatar
tavo_80816 is on a distinguished road
In the process of replacing the timing belt, my mechanic showed me this....cracked/broken block where engine mount goes and this gunk inside the water pump....
Per my mechanic, he thinks that the gunk is some kind of leak stop substance and the engine probably either has a coolant leak or overheated previously.
Regarding the crack and coil insert he thinks it could cause problems in the future since this engine tilt a lot during acceleration.
Anyone had these problems in the past?
'91 Prelude Si Rosso Corsa Red (5spd swap DONE!)
'01 E38
'02 E53
tavo_80816 is offline   Reply With Quote Quick reply to this message
Old 04-18-2017, 12:37 PM   #2
MustardCat
Memento Mori
MustardCat's Avatar
MustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the InternetMustardCat is the King of the Internet
I would pull that current insert then add a helicoil to the deeper portion. Then use a longer bolt that makes use of those deeper threads.
For the cooling system I would try flushing as much of that out as you can, radiator is probably full of it as well.
MustardCat is offline   Reply With Quote Quick reply to this message
Old 04-18-2017, 01:05 PM   #3
tavo_80816
tavo_80816's Avatar
This engine is currently sitting on a pallet since it arrived from a Canadian engine company a few days ago. I put it on the bed of a pick up truck and had the mechanic change the timing belt but after his recommendation, I didn't change the belt because he thinks that these two problems will cause me a headache down the road.
I don't know if that gunk in the water pump is a big deal or not. I have never seen that before in any of my cars. It has the consistency of mud.
'01 E38
'02 E53
Old 04-18-2017, 01:18 PM   #4
tavo_80816
tavo_80816's Avatar
It looks like using a same size but longer bolt will reach the deeper threads. I'm just worried that the crack will get bigger and cause problems later? Or will the other bolts on the mount be enough to hold it in place?
I would hate to ship back the engine to Canada cuz it would cost a lot of money.
'01 E38
'02 E53
Old 04-18-2017, 02:55 PM   #5
MustardCat
Memento Mori
MustardCat's Avatar
If you just bought it then send it back, it's a defective product. Why not just buy a used engine local?
Old 04-18-2017, 03:07 PM   #6
tavo_80816
tavo_80816's Avatar
I called some of the Southern California engine places and no one has the B20A or b20a5. I'm planning on sending it back just sucks that I'm going have to pay the shipping back to Canada.... but I rather lose $300 on shipping than $1200 I spent on it
'01 E38
'02 E53
Old 04-18-2017, 04:05 PM   #7
MustardCat
Memento Mori
MustardCat's Avatar
Well you could just buy 1funryds B series swap mounts and then buy a B20b for less than $600 shipped.
But you may just need to call around more, are you under time pressure? I'm sure if you just called around once a week a B20a5 would turn up locally. Or maybe find a junk car with running engine on CL...
Old 04-18-2017, 04:09 PM   #8
88SE Lude
Prelude Aficionado
88SE Lude's Avatar
88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of88SE Lude has much to be proud of
That definitely needs to go back... or you get a substantial refund on it.
I'd also be claiming any costs back for you to return it, not your fault they've sold you worthless crap
And yes that is some stoplleak crap in it, that alone says the engine may have had problems.
"You are not entitled to an opinion. An opinion is what you have when you don't have any facts. When you have the facts, you don't need an opinion"
MustardCat - "You have free access to people with decades worth of experience here. Being asked to format your posts in a readable manner is very reasonable. Call your local Honda dealer and see how much they want per hour to have a master tech diagnose your problem..."
88SE Lude is offline   Reply With Quote Quick reply to this message
Old 04-19-2017, 10:11 AM   #9
tavo_80816
tavo_80816's Avatar
Company told me that if my mechanic could swap a new head gasket, that they would refund me the cost for it so I could have piece of mind regarding the stopleak issue.
Worth it?
Engine has good compression right now as it is.
'01 E38
'02 E53
Old 04-19-2017, 11:08 AM   #10
88SE Lude
Prelude Aficionado
88SE Lude's Avatar
And what about the damage to the mountings?
As a mechanic I'd be charging double(slight exaggeration?) the normal cost for having to clean all that crap out of the engine. It'd be done properly rather than a quick fix but hey...
I guess it depends on exactly how much they'll be giving you back.
Old 04-19-2017, 02:36 PM   #11
tavo_80816
tavo_80816's Avatar
Spent $900 plus $290 for shipping.
They offered to refund me $300
'01 E38
'02 E53
Old 04-20-2017, 03:55 PM   #12
1funryd
1funryd is a jewel in the rough1funryd is a jewel in the rough1funryd is a jewel in the rough1funryd is a jewel in the rough
Send a message via AIM to 1funryd Send a message via MSN to 1funryd Send a message via Yahoo to 1funryd
Wow Tavo!!! That is colossal mess right there.
I would have just invested into my B-Series swap kit and gone the B20b swap.
You would have not lost any power or torque and had better support for the engine and tranny.
My Facebook page -
Sean
3rd Gen Aftermarket Manager
(Clik Here)
Email:
(Danny19 - JDM RH Drive) (1Funryd - H23 Swap) (B20luda - Turbo Charged H22)Representing All of 3rd Gens!!!
1funryd is offline   Reply With Quote Quick reply to this message
Old 04-20-2017, 07:52 PM   #13
88SE Lude
Prelude Aficionado
88SE Lude's Avatar
Personally I think that it pathetic. But ask your mechanic how much it'll cost to put everything right and you have a number to work with.
Old 04-20-2017, 10:07 PM   #14
Run_Away
Lude Boss
Run_Away's Avatar
Run_Away will become famous soon enough
I'd also be sending it back.
The sellers probably didn't know about the damage since it was all covered. At this point unless they're really slimey and would be willing to resell it without disclosing the issues it has, it's fairly worthless to them. So if you decide to keep it, you should be getting a lot more money back.
If the head is coming off, this might afford better access to repair the cracked mount. I'd be asking a machine shop if it could be welded and the block decked.
The broken mount is the bigger issue vs the cooling system crud IMO.
-Ben
Run_Away is offline   Reply With Quote Quick reply to this message
Old 04-21-2017, 12:01 AM   #15
tavo_80816
tavo_80816's Avatar
the swap kit alone is $700.
Im not doing this for power and torque, I just need my commuter car back on the road.
'01 E38
'02 E53
Old 04-21-2017, 12:02 AM   #16
tavo_80816
tavo_80816's Avatar
I asked for $500 back....
'01 E38
'02 E53
Old 04-21-2017, 08:44 AM   #17
88SE Lude
Prelude Aficionado
88SE Lude's Avatar
I'd accept nothing less. If they argue tell them you'll be sending it back for full refund of cost and shipping both ways.... it is not fit for purpose so entirely their probalem.
Old 04-21-2017, 07:21 PM   #18
tavo_80816
tavo_80816's Avatar
lowest price for shipping I found was $800!!! I was like wtf. how can it be so much for freight services?
Still waiting for their decision....
'01 E38
'02 E53
