Go Back   Preludepower.com > Performance and Style > Naturally Aspirated
Reload this Page Porting/Butterfly removal on a stock IM
Home Forums Albums POTM Garage iTrader Arcade PP Store
Register FAQ Members List Calendar Mark Forums Read
Ads By Google
Old 11-20-2009, 09:37 PM   #1
MommysLittleMonster
Grinnin' like I'm guilty
MommysLittleMonster's Avatar
MommysLittleMonster is a jewel in the roughMommysLittleMonster is a jewel in the roughMommysLittleMonster is a jewel in the roughMommysLittleMonster is a jewel in the rough
Send a message via AIM to MommysLittleMonster
Question Porting/Butterfly removal on a stock IM
As many of you know, i'm planning a tight budget, mild N/A build this winter for my 'Lude. I was throwing around some "free hp" ideas in my head today, and the idea of messing with the stock intake manifold.
My question is- would removing the butterfly valves (removing the bar & butterflies, then plugging the holes) & mildly porting the stock manifold be worth the hassle, and has anyone done it before/seen a dynograph of the results?
I plan on getting the head rebuilt (and possibly ported), removing the balance shaft, and getting the car tuned with a VAFC-II- would buying another stock IM (cheap) and porting it be worth the effort?
Thanks in advance, motor gurus.
170whp / 145lbs-ft
MommysLittleMonster is offline   Reply With Quote
Old 11-20-2009, 09:49 PM   #2
viper_boy403
Vrooom PSHHHH
viper_boy403's Avatar
viper_boy403 has a spectacular aura aboutviper_boy403 has a spectacular aura aboutviper_boy403 has a spectacular aura about
Send a message via AIM to viper_boy403
Unless you want to pull the motor to remove the shafts, just pull the belt off the balance shaft gears. Same power result, but without the weight reduction
Doing what you're describing with the IM is essentially making your own Blacktrax spacer, which will give you gains similar to the last dyno chart on the right side of this page: http://blacktrax.net/products/Intake..._Manifold.html
- Competition Clutch - MFactory - Prosport - Skunk2 - Hondata - Seibon - H&R- KYB - Tial - RC Engineering -
- Energy Suspension - Vibrant - ES Tuning Systems - Aeromotive -
BOOSTED
1997 San Marino red base
-Andrew-
viper_boy403 is offline   Reply With Quote
Old 11-20-2009, 09:54 PM   #3
MommysLittleMonster
Well, the motor is coming out anyway so it's not a big issue. The whole top end is coming off, so i figured while the intake was off i would mess around with it a little.
Looks like somewhat decent gains. I'll need a tune FOR SURE if i decide to go through with it.
170whp / 145lbs-ft
Old 11-20-2009, 10:04 PM   #4
meanshyguy
Preludepower Member
meanshyguy's Avatar
meanshyguy is on a distinguished road
I have an H22 modified like that, I never tuned it when it was on my last build, but for what I see on those graphs it probably is worth your time.
meanshyguy is offline   Reply With Quote
Old 11-20-2009, 10:20 PM   #5
nusdogg
nusdogg's Avatar
nusdogg is on a distinguished road
I'm thinking about removing my stock iab spacer and replace it with a blacktrax one.
200whp/156wtq
nusdogg is offline   Reply With Quote
Old 11-20-2009, 10:22 PM   #6
H22A_lude
Preludepower Member
H22A_lude's Avatar
H22A_lude is on a distinguished road
Their has yet to be an independent dyno compairison of removing the butterfly valves vs the OEM manifold. I'd look into some IM theory before I started messing with plenum spacers and what not.
2000 S2000 - K&N FIPK intake w/ BPI stack, HKS 75mm single exhaust, AUT cooling plate on the way...what next?
1992 Prelude - H22A, CAI, JDM RS-R header, 60mm test-pipe/exhaust, S300, complete Mugen Aero kit, 16" Motegi Traklites, one-peice headlights with TSX projectors, KYB AGX struts w/ Tanabe springs ect...needs a new tranny and the IM needs to go back on...I may continue to part this out
H22A_lude is offline   Reply With Quote
Old 11-20-2009, 10:41 PM   #7
MommysLittleMonster
I think i'm gonna buy another stock IM from another member on here, then fuck around with it. For $75, i don't have much to lose.
I was reading up on a thread on H-T that Blake posted in two years ago. I was hoping to get a little insight from a few N/A gurus on here, any advice is welcomed though. By removing the butterfly valves, i'm increasing the air velocity quite a bit inside the manifold- but i'm not really messing with the overall volume much.
I will undoubtedly get my car tuned directly afterward, the thing i would be most afraid of is shifting my air/fuel ratio with the difference in airflow over the stock tune. The last thing i want is a MASSIVE rich/lean condition on any point of the map- from what i've read, that immanent.
170whp / 145lbs-ft
Old 11-21-2009, 02:07 AM   #8
NavaSoulja
NavaSoulja's Avatar
NavaSoulja is on a distinguished road
From what I've heard, removing the butterflies would lose you some low end torque, but your midrange to top end would increase.
NavaSoulja is offline   Reply With Quote
Old 11-21-2009, 02:46 PM   #9
H22A_lude
Preludepower Member
H22A_lude's Avatar
Maybe, maybe not. You'll loose the butterfly valves that will loose low end torque but also think about the length of runner you'd be getting rit of. That could ether be good for top end, midrange or low end. IM theory is a bitch.
Something to be noted is the fact that more and more people are running modified OEM manifold on their high HP set-ups. But then again, their isn't many options for us H22 guys. I might dig into my OEM manifold and see what happens vs the Euro R.
Old 11-21-2009, 07:32 PM   #10
98vtec
Gangster White Walls
98vtec's Avatar
98vtec is a jewel in the rough98vtec is a jewel in the rough98vtec is a jewel in the rough98vtec is a jewel in the rough
take the plate out completely.
xXx Performance
South East Neptune and eCtune Tuner
-- UpRev / Haltech / AEM / DTAfast
98vtec is offline   Reply With Quote
Old 11-21-2009, 07:43 PM   #11
meanshyguy
Preludepower Member
meanshyguy's Avatar
What about stacking up two spacers, people have done it before, some dyno graphs would be nice!
Old 11-21-2009, 07:51 PM   #12
Robert Taylor
Robert Taylor is on a distinguished road
A while back just for the hell of it I installed a y in the vacuum line going to the actuator that opens and closes the valve at the air intake input .
I then ran a vacuum line from that y to the actuator that controls the secondary runners which caused the runners to change over about 500 rpm sooner . After doing this mod , I went for a drive and found that I lost mid rpm power so based on my little experiment I would say don't remove the valve . If anyone else wants to try this little experiment out all you need is 3' of hose and a y connector .
Robert Taylor is offline   Reply With Quote
Old 11-21-2009, 08:23 PM   #13
CB7Scud
CB7Scud's Avatar
CB7Scud is on a distinguished road
i plan on doing this sometime this winter, and im going to plug the holes that the butterfly rod went through with jb weld and port match my manifold and head.
"your cars help you pick up girls, all mine picks up is groceries."
CB7Scud is offline   Reply With Quote
Old 11-21-2009, 09:45 PM   #14
deafy
deafy's Avatar
deafy will become famous soon enough
Re: Porting/Butterfly removal on a stock IM
How much gain is there with the blacktrax spacers? More volume on boosted setup makes more power or is that applicable to n/a only?
Turbo 5th gen
Status: Out of the garage with OEM lip kit finally. Looks tons better.
deafy is offline   Reply With Quote
Old 11-22-2009, 01:55 AM   #15
MommysLittleMonster
Think that's the best way to go Blake? I was thinking just modifying the stock plate.
I dunno... looks like decent gains. Maybe i'll just blade the stock plate.
170whp / 145lbs-ft
Old 11-22-2009, 02:29 AM   #16
98vtec
98vtec's Avatar
im not going to suggest it for no reason...
xXx Performance
Old 11-22-2009, 02:34 AM   #17
MommysLittleMonster
Oh come on, i know you like to post useless information an mislead people!
/sarcasm.
Worth a shot, what the hell. I'll pop off the plate and see what happens. Thanks Blake, appreciate the guidance.
170whp / 145lbs-ft
Old 11-22-2009, 03:36 PM   #18
H22inURface
H22inURface!
H22inURface is on a distinguished road
/sarcasm.
whats that gonna do without a tune?
H22inURface is offline   Reply With Quote
Old 11-22-2009, 04:14 PM   #19
marcus81184
marcus81184's Avatar
marcus81184 is on a distinguished road
I removed mine, and ported my stock im, if my numbers meant anything. Free mods ftw.
marcus81184 is offline   Reply With Quote
Old 11-22-2009, 07:58 PM   #20
MommysLittleMonster
Nothing. I'll be getting a tune this spring for sure.
170whp / 145lbs-ft
Old 11-22-2009, 07:58 PM   #21
g-gameslude
Preludepower Member
g-gameslude's Avatar
g-gameslude is on a distinguished road
Stacking blacktrax spacers does not increase plenum volume; it will increase the runner length which would in turn move your powerband down a little bit. Remove the spacer plate completely on a h22. Plate stacking would be better for an h23 since they don't rev as high.
g-gameslude is offline   Reply With Quote
Old 11-23-2009, 11:24 PM   #22
MommysLittleMonster
I think i'm gonna have to be the guinea pig for this one. I may go ahead and buy the other stock intake to play with.
170whp / 145lbs-ft
Old 11-24-2009, 12:11 AM   #23
viper_boy403
Vrooom PSHHHH
If you pull the plate out completely, do you need to get shorter bolts? Hell, if thats the best way to do it I'll just yank it out tomorrow lol. I have a friend with tuning equipment and we've been messing with our basemaps so it will give me a chance to see how this would effect the engine
BOOSTED
-Andrew-
Old 11-24-2009, 01:51 AM   #24
H22A_lude
Preludepower Member
H22A_lude's Avatar
I was under the impression that the spacers were just hollow and increased the plenum volume. Maybe your right though.
Also, check out runners and pulse tuning. The basic way to look at it is like you did, but this is wrong. It all depends on what pulse you tune for. You could be right in this case, but like I said earlier, IM theory/tuning is a bitch.
Old 11-24-2009, 08:05 AM   #25
marcus81184
Uh... it has been done already.
  • Submit Thread to Digg Digg
  • Submit Thread to del.icio.us del.icio.us
  • Submit Thread to StumbleUpon StumbleUpon
  • Submit Thread to Google Google
  • Ads By Google
    « Previous Thread | Next Thread »
    These are the 100 most searched terms
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b21a1 car motivational posters convertible prelude dashboard paint edge2lyfe view profile floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22a4 specs h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen how to text your girlfriend hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews pcv valve symptoms power prelude prelude prelude convertible prelude forum prelude forums prelude power preludepower preludepower.com projector retrofit racing hart cp-035 rattle can paint job song suggester sweet things to say to your girlfriend in a text sweet things to say to your girlfriend over text sweet things to text your girlfriend things to text about things to text your girlfriend what to text your girlfriend www.preludepower.com
    You may not post new threads
    You may not post replies
    KickItBack = Cash Back
    Google
    One of the largest message boards on the web !
    Powered by vBulletin® Version 3.7.2
    Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
    Copyright ©2002 - 2006, Preludepower.com
