Latest Dyno Results - H22 w/ Type-S Pistons, Skunk2 Pro2 Cams, Tri-Y 4-2-1 Header,etc - Honda Prelude Forum : Honda Prelude Forums
Old 04-16-2012, 02:15 PM   #1
Mike95lude
Mike95lude is on a distinguished road
Went back to the same dyno yesterday, that I used way back in Sept. 2009 for the original dyno session, with Marshall (92TypeR on honda-tech) to see what the results of my current setup would be and try playing with the cam gears a bit. We were short on time, so only had a chance to try two different cam gear settings. Our first dyno pull before any tuning netted us 231whp and ~160wtq, if I recall correctly.
Setup changes worth mentioning since the last dyno are:
-Private Label Mfg. Tri-Y 4-2-1 Header (previous was GReddy Header w/ 2.5" modified collector)
-3" Short Ram Intake w/ Blox Velocity Stack & Filter (previous was 3" Fujita F5 Cold Air Intake, no velocity stack)
And here is a before/after comparing one of our graphs from our previous dyno session back in 2009 to yesterday:
I am definitely quite pleased with the gains. Clearly this setup is working pretty well....better than I had expected
Mike
Mike95lude is offline   Reply With Quote Quick reply to this message
Old 04-16-2012, 03:51 PM   #2
element600rr
element600rr will become famous soon enough
pretty solid numbers id be proud ..
element600rr is offline   Reply With Quote Quick reply to this message
Old 04-16-2012, 06:33 PM   #3
Mike95lude
Thanks . I am happy with it
Old 04-16-2012, 10:54 PM   #4
hdragster
hdragster is on a distinguished road
Dang mike that hytech replica header made your car breath a whole lot better! Glad you made some good numbers!
hdragster is offline   Reply With Quote Quick reply to this message
Old 04-17-2012, 03:55 PM   #5
element600rr
what all parts do you have ? intake ? tb /size ? valve train ? id like to know a little more of the specifics ..
Old 04-17-2012, 10:59 PM   #6
nusdogg
Lude Cray
nusdogg's Avatar
nusdogg is on a distinguished road
Nice numbers Mike! I plan on getting a set of 11.5:1 CR Mahles pistons too to get that power. I have the same setup you have except I do not have the pistons yet.
204whp/157wtq
nusdogg is offline   Reply With Quote Quick reply to this message
Old 04-18-2012, 07:43 AM   #7
L0B5TA
I lub Denny one tiem
L0B5TA's Avatar
L0B5TA has a spectacular aura aboutL0B5TA has a spectacular aura about
pretty damn good numbers. nice job man
J.L.D.E.P.P.M.S.3.C.N.Y.C.N.V.M.A.D
L0B5TA is offline   Reply With Quote Quick reply to this message
Old 04-18-2012, 08:00 AM   #8
evoludersir
Lude Boss
evoludersir's Avatar
evoludersir is on a distinguished road
Send a message via AIM to evoludersir Send a message via MSN to evoludersir
Nice hp gain from adjusting the cam setting.
No Boost.
No Bottle.
Just PURE THROTTLE!
evoludersir is offline   Reply With Quote Quick reply to this message
Old 04-18-2012, 10:54 AM   #9
Mike95lude
Chassis: '94 Prelude VTEC (BB1)
Engine: ('95 H22A1 rebuilt with the following parts at ~85k miles)
-JDM Prelude Type-S Pistons (11:1 c/r) - Std bore, dropped right in, no hone
-Eagle Rods
-OEM Crank Pulley
-Kaizenspeed Balance Shaft Eliminator kit
-Skunk2 Pro 2 Camshafts
-Skunk2 Tuner Cam Gears
-Skunk2 Pro Valve Springs w/ Spring base kit & Titanium Retainers
-OEM Valves
-Skunk2 Intake Manifold
-Professional Products 68mm Throttle Body
-3" Short Ram Intake w/ BLOX Velocity Stack & Filter
Fuel:
-Precision 440cc Injectors
-OEM Fuel Pump
-OEM FPR
Exhaust:
-Magnaflow Spun Metallic 3" High Flow Cat
-Custom 3" Cat-back Exhaust with 2 resonators and Dynomax VT Muffler
Transmission:
-Competition Clutch Lightweight Flywheel (13.65 lbs)
-Exedy Stage 1 Organic Racing Clutch
-OBX LSD
Tuned by 92TypeR on eCtune (P28 ECU)
Old 04-18-2012, 10:59 AM   #10
Mike95lude
Thanks! I didn't expect the header to make such a difference honestly. I figured my GReddy 4-2-1 wouldn't be too bad since I had modified the collector to 2.5".
Nice! Did you find a good shop that has the proper tooling to hone our FRM cylinder walls? I wanted to go with those pistons too, but no machine shops in my area seemed to be able to hone FRM cylinders.
Thanks
Thanks! Definitely most of the gain was from the header. I think we only gained about 4-5whp peak from tuning the cam gears. We only tried two different cam gear settings on the dyno due to time constaints.
Old 04-18-2012, 03:13 PM   #11
element600rr
-Eagle Rods
-OEM Crank Pulley
-OEM Valves
Fuel:
-OEM Fuel Pump
-OEM FPR
Exhaust:
Transmission:
-OBX LSD
thanks for the info .. appreciated ..
Old 04-18-2012, 07:28 PM   #12
evoludersir
Lude Boss
lord oh MIGHTY, you gained 22whp from tuning with the new header and cam gear adj. thats insane. i can't believe that header boosted hp that high. can't wait for a legit tune with no time constraint.
No Boost.
No Bottle.
Just PURE THROTTLE!
Old 04-18-2012, 08:54 PM   #13
zuptidi
Lude Cray
zuptidi's Avatar
zuptidi has a spectacular aura aboutzuptidi has a spectacular aura about
that greddy was really choking you up
2000 Lude H23vtec Bluetop (For Sale)
zuptidi is offline   Reply With Quote Quick reply to this message
Old 04-19-2012, 09:58 AM   #14
Mike95lude
Yeah, very impressed by the gains with the header change. Would be interested in finding out how much more I could gain with futher cam gear tuning.
Old 04-19-2012, 01:11 PM   #15
Charlie15
Charlie15 is on a distinguished road
Great job Mike !
Is this guy on E85? (sorry if i missed that)
Yeah tuning with limited time stucks cause you always wonder how much more it could of made.
Charlie15 is offline   Reply With Quote Quick reply to this message
Old 04-19-2012, 04:59 PM   #16
Mike95lude
Originally Posted by Charlie15 View Post
Great job Mike !
Thanks
92 octane pump gas
